Question about Kenmore 56239 / 56232 / 56234 / 56236 Side by Side Refrigerator
What water filter to use on Kenmore 56232. Thank you.
Kenmore coldspot- 106 Model 9537654
The Kenmore Model 106.9537654 does not appear to have a water filter. Thanks Sea Breeze
Here is a PDF of the parts=> 106.9537654 Parts
Jul 15, 2013 | Kenmore Refrigerators
Unit is running but compressor is short cycling and amping too high 15.5 amps full load is 6.5
I would try a new compresser overload relay. This is what starts the compresser and they have issues with them. Also some have a capatator that may need changed also. Some applance stores have what called 3n1. Which has all the things you need. I hope this helps.
Sep 07, 2011 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
My water filter keeps coming out when i press the dispencer to get water
Hello, Thank You for using FixYa. I will be helping you today. The only way this can happen is if the filter is not installed correct. Make sure you are turning it all the way in. Unless the filter or housing is damaged. Look at the filter and make sure it is not damaged.
Thank You and please rate my answer if it was helpful..
Jun 29, 2011 | Kenmore Side by Side Refrigerator
REFRIGERATOR NOT COOLING
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
I have a Kenmore Coldspot side by side. The ice maker is not working.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Nov 18, 2010 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
I need help replacing a Kenmore Elite Water Filter - 46- 9010
insert it so it is vertical and then rotate one quarter turn to the right so it is now horizontal nad the line matches the grill on the front of the fridge.
Nov 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KENMORE SIDE BY SIDE REFRIGERATOR. QUESTION REF WATER FILTER
need to replace the filter every six months and yes you can get them at Sears but not Walmart
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Water filter not working
Freezer too cold, tube in door frozen. This happens to my freezer when my children turn the freezer temp too low.
Mar 20, 2007 | Kenmore 54362 / 54364 / 54369 Side by Side...
Kenmore 56239 / 56232 / 56234 / 56236 Side by Side Refrigerator Logo
19 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
