Question about Sony Televison & Video
I have a Sony EV-S900 Hi8 video recorders that keeps popping the tape drawer back out whenever I try to play a tape back. Why will it not load the tape?
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
night71
  • 328 Answers
SOURCE: I have a Fuji Hi8 MP p6-120 that will not play
Check the top of the tape. There is a slider which open a slot or closes it. It should be closed.
Posted on Oct 26, 2007
SOURCE: My Sony Video Camera quit playing the tapes while I was recording. The motor
Your expert suggested getting a head cleaning cartridge which I've ordered. We'll hope that solves the problem. Thanks for asking.
Posted on Mar 23, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
AlmostBob
  • 550 Answers
SOURCE: problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Posted on Oct 23, 2008
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
I can't play a hi8 cassette recorded in another camera y my camera, what can i do?
DCR-TRV130 is not capable of playing back 8mm or Hi8 tapes recorded on analog camcorders. Digital recording playback only.
Feb 16, 2010 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony TRV510-playback, audio choppy, image isn't clear
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
I tried it, and IT WORKED!!
Jul 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Sony TRV460 D8-->Hi8 switching
I too was having a problem playing back my 8mm in my TRV460. The audio and video was both very glitchy. I tried what dyz66 said and rewound to the start of the tape,and then recorded about 10 seconds of meaninless video. After that the whole tape played nice and clear. Thanks for the idea. I believe from here on out I'm going to buy some new tapes to try and avoid this.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Hi8 camera tapes
any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Feb 12, 2008 | Sony Hi8 Hi-8 Tape
Dec 06, 2007 | Video Cameras
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
216 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
