Question about Fisher Paykel EcoSmart GWL15
My washing problem began with water leaking out of the base (not because of an overloaded tank), and it just now completely stopped working. The power won't go on at all. I have tried unplugging it and letting it sit for 60 seconds as suggested by the owner's manual. Any idea of what could have caused this problem? I guess I'll call the repairman tomorrow.
  • Fisher Master
  • 713 Answers
Hi just read your posting There are 2 reasons why your machine wont power up and they are 1---you control module is faulty or your drain pump is open circuit.What concerns me is the fact you have a leak from the bottom.Has your machine been noisy on spin?The water could have been coming from the main seal and possibly damaged your position sensor or motor.Either way you will have to replace the control board or pump.Please reply for further assistance and to let me know how you got on when the service tech looks at your machine.Looking forward to your reply.
Posted on May 23, 2011
  • ckay789
    ckay789 Feb 04, 2013
    I have the same model machine and it just did the same thing, no power at all. I have replaced the control module and the pump, still no power. Is there a fuse in here somewhere that has blown that I need to replace inline from the pump? The new pumps come with an inline fuse I am told.
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Subzero 680 water dispenser working inconsistently.
This sounds like the inlet water solenoid valve is faulty. This valve is connected to the water supply line coming from your house.
Jan 26, 2015 | Refrigerators
Toilet water tank keeps fillng above the water line. No leak anywhere.
Sounds like the float is not attached...it should be attached to the flapper ....it may need adjusting
Oct 16, 2012 | Fluidmaster Toilet Tank Complete Repair...
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    How do i get my bissell to stop leaking water?
    The rubber gasket on the bottom of the 2-in-1 tank is probably lodged in the base of the unit. It should be connected to the nozzle on the bottom of the 2-in-1 tank. You can pull it out of the base and reattach it to the tank. This should stop it from leaking. The formula tank on the back has the same gasket so you can pull that out and see how it should fit on. Hope that helps.
    Apr 05, 2012 | Bissell 2X Proheat 9200 rug cleaner
    About every 20 minutes or so, more water is released into the bowl from the tank. Toilet is less than 1 yr old ,model 4021
    The flapper that stops water from entering the bowl after flushing needs adjustment. The chain is probably to short.
    Aug 20, 2011 | American Standard 4021 White Cadet 3...
    Stopped
    This is a typical Anti Flood system activation. This system activates when water leaks onto the floor of the machiene due to a leak fault (pipe/hose clamp/ partly blocked pipe). The machiene automatically switches to pump out mode and stops water inlet. The anti flood system is a polystireen float / micro switch at the base of the machiene floor. Dry the floor and drectify the leak and it should work.
    Jan 24, 2010 | Baumatic 23 in. BDW13 Built-in Dishwasher
    Whirlpool washer stops after agitation cycle
    Maybe check the belt is it cracked worn or fibers showing if so replace it
    Jul 26, 2009 | Whirlpool Washing Machines
    Fisher Paykel EcoSmart GWL15 Logo
    604 people viewed this question
    Top Fisher Washing Machines Experts
    Dan Webster
    Dan Webster
    dweatherby
    Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
