Question about Olympus m:robe MR-100 Digital Media Player
M:robe error invalid/missing file
i have an m:robe 100. the problem is that when i switch it on, it gives the following error: invalid/missing file. however, i am able to use it as a memory card. i have come to know, that the problem can be solved by reinstalling the system files, however, i have not been able to find those files from m:robe's site. it would be helpful if someone would be able to send me the link for these system files.
thanking you,
kishore
  • 5 more comments
  • pumukius Nov 23, 2008
  • jward3kids Feb 04, 2009
    mine says invalid/missing file and I cannot turn it off
  • maya_turkmen Feb 13, 2009
    i couldn't find these system files on web..
  • Anonymous Mar 31, 2009
    the machine Don't power-off
    always show on the screen that invalid/missing file...
    please help me...
  • allab nacer Apr 09, 2009
  • Anonymous May 26, 2009
    i can't use my m:robe be it say invalid/missing file. how can i fix it?
Hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Posted on Aug 21, 2009
I have aproblem with my m robe which say fatal system error service required 004 plese can can give me the solution to this
Posted on Sep 06, 2008
  • 51 Answers
@kishore okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
after tht install the firmware http://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..before installing the firmware make sure tht u reset the player ..after following all the instructions of the firmware try to synch the player to check whether it detects music and finally restart your m:robe to take effect..!!
Posted on Feb 09, 2010
I had the same problem once, I solved it by opening the m:robe in windows explorer, then replacing all the files with the files that were on it originally. If you don't have those files, there is a community somewhere that has them.
Posted on Sep 17, 2008
How to fix my m:robe..when i turn on it doesnt open andwhen i plug it in compter it will open but its color red only how can i fix it?pls help me
Posted on Mar 04, 2011
Não liga
Hello, my name is Louise and I live in Brazil. When I try to plug my m: robe 8GB appears on the screen the following message. INVALID / MISSING FILE. What is the solution to this problem?
Sep 23, 2010 | Olympus m:robe MR-500i MP3 Player
Hi. My name is Natalie. I got an m:robe for my 16th birthday at MTV'S TRL. Today, I just plugged this in to my computer and i deleted songs, put some in, and now, its saying INVALID/MISSING FILE. After you...
okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index extract the files to your player and then
Dec 29, 2009 | Olympus m:robe MR-100 Digital Media Player
I too have a fatal error message on my m-robe m-100
Depending on what the error is, it's probably pretty easy to fix. If it's showing error 004, then it's having a problem loading the firmware from the hard drive. Usually this is from a deleted/corrupt file. To find out what the problem is, do this:
Plug the M:Robe into your computer, then when it says charging battery, push the power button and hold the player up to your ear. If you can hear the hard drive spinning, then it's almost definitely just a software issue. If you don't hear the hard drive spinning, it may have a dead drive. If that's the case, you'll have to send it in to have it fixed or buy a new one. There's usually several cheap ones on ebay that have same software problem, and you can just swap parts, or fix the one you bought.
To fix the software issue:
1. Download the firmware from this page: http://www.olympusamerica.com/cpg_section/software_results.asp?id=1145&os=w
2. Plug in your mp3 player, and turn it on.
3. Run the program you downloaded, and follow the instructions.
If step 3 won't work, it could be a damaged file system. If that's the case, open up your 'My Computer' and find the M:Robe drive, then format it, then do step 3 again. You will have to put all your music back on it.
Dec 04, 2008 | Audio Players & Recorders
Olympus mrobe
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Oct 09, 2008 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe 100 missing file
Sep 12, 2008 | Olympus m:robe MR-500i MP3 Player
Error code : 0400001f
fatal system error
service required/004
Nov 26, 2007 | Olympus m:robe MR-100 Digital Media Player
M:Robe not ejected from XP,, help!
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Olympus m:robe MR-100 Digital Media Player
Help!!
upload the firmware again
Apr 13, 2007 | Olympus m:robe MR-100 Digital Media Player
HELP
Did you go to Olympus's m:robe site and download the firmware and install it again?
Feb 01, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus mr-100 mp3 player
This is a photo of the inside of the M-robe. I tried the suggestions you gave with no improvement. I did notice that the other end of the hdd lead where it connects to the mother board was not straight in the board socket
When you remove this lead from the motherboard, make sure you don’t bend it or stress it out of shape. before you attempt to put this lead back in, make sure the small plastic lock strip is lifted out of the way. Then press the lead firmly back onto the receptacle. Then lightly press the plastic lock strip back over where the connector is on the board here. If you have completed this connection correctly and no other damage has been done, your M-Robe should start up. Good luck
Graham Everson
gdprassem@gmail.com
Jan 25, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe MR-100 Digital Media Player Logo
2,985 people viewed this question
Top Olympus Audio Players & Recorders Experts
Mitch Davis
Mitch Davis
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
