Question about Sport & Outdoor - Others
Have bought Ruger .270 rifle w. Simmons scope. Are the windage and elevation adjustment screws covered by screw-on caps?
  • 8,197 Answers
Yes there is a screw on cap covering the adjustments. Here is one of there general manuals on the link below.
http://simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Posted on May 23, 2011
I cannot move the adjustment knobs on the windage and elevation of the scope
Some time the screw is a set screw and needs to be loosened to adjust the valve. Others are adjusted by the screw. Either way you might need a larger driver the break the tension on the screw. Factory set it can be tight.
Nov 02, 2013 | Konus Pro 275 Muzzleloader Rifle ...3-9x...
Scope insternal adjustments do not do anything. This is the second new scope I have had this problem with. I have borescoped the rifle and no change in either windage or elevation screws over entire...
One of the things about bore sighting is there is no shock to the scope. They are meant to have some shock that goes along with an adjustment. Try smaller adjustments and tap the tube of the scope with a screw driver handle after every adjustment. Not so hard you dent it but hard enough to get stuff moving. Hope this Helps FixYa up.
Aug 24, 2011 | Simmons 511070 4x32 22 MAG Riflescope -...
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Have no idea how to set up the sight on my air gun
I don't have this particular model. Chances are, those are not "knobs" but caps. Remove the caps as you would remove the caps from a pill bottle. Underneath, you should find the adjustment dials for windage and elevation,
You can download a generic Simmons scope manual here:
http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Apr 04, 2010 | Simmons 511070 4x32 22 MAG Riflescope -...
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
I bought a used scope with no manual. On the front of the scope it turns like the back but it has ranges on it do I need to know what range I am shooting for the rifle to be accurite
Take the bolt out of the rifle so you can sight down the barrel to the target. Get the target bullseye in the center of the barrel. Now look through the scope to see where it is. Adjust the windage and elevation screws to get the cross hairs on the bullseye. Look through the barrel several times to make sure the gun did not move off the target during the adjustments. A concrete bench with sandbags is best to use for this.
Dec 05, 2009 | Burris Fullfield II Riflescope
I have a 3 x 9 x 50 rifle scope
if you cannot adjust it using the windage and elevation screws, you have a defective scope. Most scopes have a warrenty. If you purchased it new,, the store from where you purchased it should replace it.
Sep 21, 2009 | Optronics Buckridge 4x32mm WA Blk Matte...
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Sport & Outdoor - Others Logo
109 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
