Question about Raymarine Raychart 425 GPS Receiver
What kind of battery do I need for Raymarine 425 chartplotter and where can I get it
  • 43 Answers
SOURCE: I Have a Raymarine Radar RL70CRC HSB2 the
If both plotter works but they have no comunikation
RESET the RL 70 AND L760
This is how it works
press the powerbutton when you have picture press the menu bottom
than systemsetup and than four seconds the menu bottom.
Do this on both plotter normaly after this it works again
Posted on Oct 22, 2009
  • 43 Answers
SOURCE: GPS antenna
If your old antena is a Seatalk or NMEA antena you can use it for your C80
If you GPS antenna is older than five year change it.
Posted on Oct 31, 2009
TechnoMarine
  • 132 Answers
SOURCE: can i connect nmea outputs from a raymarine e-80
yes, you need the NMEA out cord set for the E 80 and hook the output of the E series to the input on the power data cord on the Garmin - out to in
Posted on Jan 16, 2010
  • 3 Answers
SOURCE: My boat is pointed in the wrong direction on my
I'm not sure where you would locate "reset to factory specifications". Look for it in the GPS menus (may be in the System) and reset, it is no big deal to reset a GPS, it will not hurt anything. I the GPS is set to back Track. To check this turn your boat around and follow the track on the lake chart. If you and your boat are now going in the same direction the GPS was set on Back Track.
Posted on Aug 31, 2010
SOURCE: What kind of batt do I need for a raychart #425
Dont know what kind but has to be soldered in place by raymarine at a cost of about 130.00
Posted on Jul 20, 2011
Raymarine a50d continuously resetting itself?
If there's a memory card installed for maps, try starting up the unit with it removed. It's possible that the card might be corrupted and stalling the start-up sequence.
May 10, 2014 | Raymarine A50D 5" Fishfinder /...
Fuses blowing on raymarine e series 125 chartplotter
It sounds like the fault is within the plotter itself. There should be any component, which shorts with main power supply, causes the blow of fuse to overload. I do advice you not to try to repair it by yourself, and contact the authorized service center.
Gopakumar Gopalan Google
Sophistacated testing instruments are needed to repair this type of devices.
Mar 21, 2014 | Raymarine GPS
Raymarine manuals for a50d
Gotcha covered!
The link below will give you access to your owner's manual for the A50D.
-Steve
Series A50 A50D A57D A70 A70D
Jan 29, 2012 | Raymarine A50D 5" Fishfinder Chartplotter...
Hello, I have just bought my Bavaria 36 in the netherlands. We have sailed her to Sweden a few days ago. The boat is equipped with a chartplotter RayMarine RC 435. During our trip we noticed the folowing:...
One thing you might check is for any corrosion in the 12VDC power cable at any point on the way to the unit. If the wires are somewhat corroded they will heat up as the unit draws power and the inherent voltage drop a from heated wires may lower the available voltage to the unit so it shuts down.
Jun 20, 2011 | Raymarine Rc435 Chartplotter
System haild
Take the Raymarine Rc 435 Chartplotter to a system or computer engineer for repairs.
Jan 22, 2011 | Raymarine Rc435 Chartplotter
What kind of batt do I need for a raychart #425 chartplotter ?
Jan 10, 2011 | Raymarine Raychart 425 GPS Receiver
How do i replace the internal battery on my raychart 425 chartplotter
Found the replacement batteries thru Allied Electronics on the web! The replacement is a Panasonic # CR2032-1HF. Raymarine said the unit was "too old and the battery was no longer available", so, went on my own search. Good Luck!
Aug 07, 2010 | Raymarine Raychart 425 GPS Receiver
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
Besides the unit what is needed to make operational a V850 fishfinder/GPS/chartplotter
for the fishfinder, a transducer to go in the water
batteries
Oct 13, 2008 | Raymarine GPS
No depth reading while on plane.
Depending on your transducer type, you may have a liquid filled type that simply needs refilling. If this is the case check for leaks and get it redone. If not it could be transducer placement or cavitation under the hull.
Jun 18, 2008 | Raymarine A65 Combo GPS...
Raymarine Raychart 425 GPS Receiver Logo
139 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
