Question about Dewalt Dc385 Reciprocating Saw 18v Tool Only
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger switch but, at this point I am not certain what it is. Can you help?
  • 2,176 Answers
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
Posted on May 24, 2011
The shaft rusted and does not hold the blade; how do I remove the rubber cowling to repair / replace the shaft?
Remove the 2 torx screws that hold the foot on the front of the tool - the boot will slide right off with the blade release lever.
DeWalt makes a shaft upgrade kit that is fairly easy to install.
Mar 08, 2015 | Dewalt Dc385 Reciprocating Saw 18v Tool...
De walt dc385
should come with a chuck key, or a key to lossen the blade. all of them lock in this manner regardless of manufacture. Check website of manufacture for this, or your mannal
good luck
Apr 30, 2013 | Saws
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
Aug 19, 2012 | Dewalt 18v Dc385 Cordless Reciprocating...
How do I get a operating manual for a DeWalt DC385 Reciprocation saw
you can download the operators manual from this site
http://servicenet.dewalt.com/Products/Detail?productNumber=DC385B#
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How do i CHANGE THE SAW BLADE
Hout40, holding saw as U would use it, is a "dog" on the right side, that U pull out.
If U turn it around and look at the other end ( with the blade end) U can see the "dog" work the inside, that releases the blade. HTH, JoeB
Feb 19, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
Cannot get saw blade to go into opening. sprayed wd40 but did no good
when you pull the yellow latch look to see it is activating mechanism sometimes it slips under it and can be a pain.........
Feb 15, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
Clamping a blade in the saw
it's either a cylinder behind fence,twist it to open,let go so it close's. or there is a lever on the side that you lift up to insert blade let down to hold in place
Apr 07, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Mar 22, 2009 | Dewalt DC385B 18v. Cordless Bare...
I Have a Dewalt DC385 type 2 Reciprocating saw. I push the trigger and it does not work all of a sudden. Could the trigger unit be bad. How can I tell if it is bad, I just dont want to keep replacing...
REMOVE THE BLADE !!!! take the handle apart and lift out the switch. keep track of the lock slide button and how it is installed. unplug the switch wires. carefully touch the wires you just unplugged onto the battery terminals. these wires lead directly to the motor. BEWARE.. if the motor components are good , the saw will run at FULL SPEED. you only need to tap the wires, DO NOT jamb them onto the battery. If the motor runs then most likely the switch is bad. If you know how to use a continuity tester then you can also check the switch. Bad moter likely culprtet is the brushes are crapped out.
Mar 12, 2009 | Dewalt DC385B 18v. Cordless Bare...
Dewalt Dc385 Reciprocating Saw 18v Tool Only Logo
253 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
