Question about Gateway 505GR PC Desktop
Gateway 505GR not showing LAN line for internet
We have a Gateway 505GR and the power went out the other day and now we can't get on the internet. When you go into my network connects the LAN local area connection is gone. I'm assuming this is a driver issue. The ethernet card is showing on with a steady burn light. I've been on the Gateway website several times and have not been able to find the driver downloads?????
I have the same problem from the same situation ( a storm ) but in device manager i dont see network adapters in the list
Posted on Nov 17, 2008
    President:
  • 2,961 Answers
Assuming it's XP,right click my computer>properties>hardware tab>device manager, then look down list for network adapters, if its there click the '+' sign, then right click on the network adapter and select uninstall.
Restart pc and the network card will be found and the driver automatically installed.
It should now be in network connections, if not reply back
Posted on Aug 15, 2008
  • skipdz1211 Jul 06, 2011
    I have the same computer and same problem as above and I tried exactly what u posted and it worked. Still no Local Area Connection but the 1394 connection was back on and connected. However, I still cannot connect to the internet. When I click Internet Explorer it reads "Internet Explorer cannot display this webpage". I click diagnose and it reads "Windows could not detect any wired or wireless network cards installed on your machine." I'm so frustrated. I don't know what to do.
  • skipdz1211 Jul 07, 2011
    I fixed it. I "disabled" the 1394 connection and rebooted. Once booted, the local area connection was back up. Problem solved.
Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Nov 20, 2008 | Gateway 505GR PC Desktop
Restore a gateway 505gr
I got a gateway 505gr that I had to restore , but I lost the disc . So I used another disc. from my newer gateway and it worked . I cant promise you anything but I will see if I can burn you a copy to try if interested . if not I got a copy of window xp pro that I can send you that will work. you can email me at rbright13@hotmail.com .
Nov 10, 2008 | Gateway 505GR PC Desktop
Gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Aug 18, 2008 | Gateway 505GR PC Desktop
Gateway 505GR
try this to update the driver..... first hit the start , go to my computer , hit view system information , hit hardware , click device manager , look for network adapters. hit the + sign beside it , right click Ethernet , and then update driver. Most the time when they need to be updated they will have a yellow ? mark beside them if not still update them . hope this helps
Aug 15, 2008 | Gateway 505GR PC Desktop
Gateway 505gr motherboard replacement
not powering up does not mean the mother board is bad , the power supply going bad is more likely to be the problem . But your tower is considered to be a mini tower ive got the same one that I replaced the mother board on . dont mess up and get the wrong size board , it will not fit!
Jul 17, 2008 | Gateway 505GR PC Desktop
Computer not showing anything
Did you check the type of the memory card the motherboard of your computer would support? It may be a DDR1 or DDR2 and also check how much memory your motherboard can hold. You disconnect the memory card and check to see if the computer would turn on.
May 27, 2008 | Gateway 505GR PC Desktop
Replacing a mother board for a gateway 505gr
First off find out what form factor the tower will support. most new mob will tell you what form factor they are.
Dec 31, 2007 | Gateway 505GR PC Desktop
Gateway 505GR PC Desktop Logo
307 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
