Question about Pacific International Pacific Evolution Girls' Mountain Bike (24Inch Wheels)
What size bolts does the rear frame take for mounting a bike rack
    Brigadier General:
  • 8,546 Answers
Since you probably need to go to a hardware store to get them anyway, you could just take the bike in and guarantee a good fit. They're probably metric. Make sure they're long enough. Get washers.
Posted on May 23, 2011
How do I replace a rear motor mount on 1997 Chrysler Cirrus?
Put a jack under the back of the frame and remove the rear frame bolts. Lower the jack enough to remove the mount. Don't go down to much as the steering linkage could come apart. This would be another problem you don't need.
Mar 30, 2016 | 1997 Chrysler Cirrus
How do you replace the rack and opinion on a 92 cutlass ceira
Here you are - power rack & pinion.
Except 2.2L and 1993-96 3.1L Engines
See Figure 1
  1. Raise the intermediate shaft seal and remove intermediate shaft-to-stub shaft pinch bolt.
  2. Remove the air cleaner and disconnect the pressure hoses from the steering gear.
  3. Raise and support the vehicle on jackstands, then remove both front wheel and tire assemblies.
  4. Remove the cotter pins and nuts from both tie rod ends. Using tool J-6627 or BT-7101, press the tie rod ends from the steering knuckle.
  5. If equipped with an Air Management pipe, remove the bracket bolt from the crossmember.
  6. Remove the 2 rear cradle mounting bolts and lower the rear of the cradle about 4-5 in. (102-127mm).
WARNING
If the rear of the cradle is lowered too far, the engine components nearest the cowl may be damaged.
  1. If equipped, remove the rack and pinion heat shield.
Fig. Fig. 1: Power rack and pinion assembly
  1. Remove the rack and pinion mounting bolts, then the gear assembly through the left wheel opening.
To install:
  1. Install the gear assembly through the left wheel opening and install the mounting bolts.
  2. Install the heat shield.
  3. Raise the rear of the cradle and install the mounting bolts.
  4. Install the bracket bolt to the crossmember under the air management pipe.
  5. Install the tie rod ends to the steering knuckles, install the retaining nuts and insert new cotter pins.
  6. Install the front wheels and lower the vehicle.
  7. Install the high pressure hoses to the steering gear and install the air cleaner.
  8. Install the intermediate shaft seal and the intermediate shaft-to-stub shaft pinch bolt.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Install an engine support fixture J-28467-A, or the equivalent.
  3. Raise and safely support the vehicle.
  4. Remove the tire and wheel assembly.
  5. Remove the intermediate shaft lower pinch bolt.
  6. Disconnect the intermediate shaft from stub shaft.
CAUTION
Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
  1. Remove the exhaust pipe hanger bracket near rear of frame including the brake line retainer and rubber exhaust pipe hangers.
  2. Remove the engine and transaxle mount nuts at the subframe.
  3. Support the rear of the subframe with jack stands.
  4. Remove the rear subframe bolts and discard.
  5. Lower the subframe for access to rack and pinion.
Do not lower the rear of the cradle too far, as damage to engine components nearest the cowl may result.
  1. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  2. Disconnect the power steering lines from the steering gear.
  3. Remove the rack and pinion mounting bolts and nuts.
  4. Remove the rack and pinion through left wheel opening.
To Install:
  1. Install the rack and pinion through left wheel opening.
  2. Install the rack and pinion mounting bolts and nuts and tighten to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm) on the pressure line.
  4. Install the power steering line clip to steering gear.
  5. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  6. Raise the subframe into position and install new frame mounting bolts. Tighten the bolts to 103 ft. lbs. (140 Nm).
  7. Remove the jack.
  8. Install the engine mount and transaxle mount nuts and tighten to 39 ft. lbs. (53 Nm).
  9. Install the exhaust pipe hanger bracket near the rear of frame including brake line retainer and rubber exhaust pipe hanger.
  10. Connect the intermediate shaft to the stub shaft and tighten the pinch bolt to 29 ft. lbs. (40 Nm).
  11. Install the tire and wheel assembly.
  12. Lower the vehicle.
  13. Remove the support fixture.
  14. Connect the negative battery cable.
  15. Refill the power steering reservoir and bleed the system.
  16. Check the front end alignment and adjust as necessary.
3.1L Engine (VIN M)
  2. Remove engine torque strut from engine.
  3. Install an engine support fixture J-28467-A, or the equivalent.
  4. Raise and safely support the vehicle.
  5. Remove the tire and wheel assembly.
  6. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  7. Remove the center engine and rear transaxle mounts from the frame.
  8. Remove the intermediate shaft lower pinch bolt.
  9. Disconnect the intermediate shaft from stub shaft.
CAUTION
  1. Remove the brace bolts and brace, including brake line brace.
  2. Support the rear of the subframe with jack stands.
  3. Remove the rear subframe bolts and discard.
  4. Lower the subframe for access to rack and pinion.
  5. Remove the steering gear heat shield.
  6. Remove the clip holding lines at rack assembly.
  7. Disconnect the power steering lines and O-rings.
  8. Remove the rack and pinion mounting bolts and nuts.
  9. Remove the rack and pinion unit through the left wheel well.
To Install:
  2. Install the rack and pinion mounting bolts and nuts and tighten the mounting bolts to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm). on the pressure line.
  5. Install the steering gear heat shield.
  7. Remove the jack.
  9. Install the brace and bolts including brake line brace.
  11. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  12. Install the tire and wheel assembly.
  13. Lower the vehicle.
  14. Remove the support fixture.
  15. Connect the negative battery cable.
  16. Refill the power steering reservoir and bleed the system.
  17. Check the front end alignment and adjust as necessary.
Nov 01, 2015 | Cars & Trucks
How to replace rack an pinion cutlass ciera 1992
You aren't saying what engine is in it, or whether it is manual or power steering. Here is the R/R procedure for power steering rack for all engine sizes.
See Figure 1
WARNING
To install:
2.2L Engine
CAUTION
To Install:
  7. Remove the jack.
3.1L Engine (VIN M)
CAUTION
To Install:
  7. Remove the jack.
How tough is it to replace the rack and pinion on a pontiac montana
It's a bit of a pain, but doable with simple tools.
Loosen the front lug nuts. Jack up the van and support it on the rails just behind the front tires (not the sub frame as you need to lower that a few inches). Remove the front tires. Disconnect the sway bar link pins, and the sway bar mounting bolts. Disconnect the tie rod ends from the knuckles. Support the rear ends of the sub frame, and remove the bolts mounting it to the van. Once the sub frame bolts are out, lower the rear end of the frame. I did this by using a jack, and placing the jack stands a couple of inches below the frame. Remove the sway bar from the van. You may need to drop the rack a bit more, but be careful as the steering shaft is still connected. You should be able to get at the bolt that attaches the rack stub to the steering rod by pushing up on the boot. Remove the sub shaft bolt. Disconnect the power steering lines from the rack (at the rack). Un-bolt the rack from the sub frame, there are two bolts. The rack should be able to be removed from the drivers side of the van. I replaced the tie rod ends and the sway bar bushings when I replaced mine (new link pins are easy at this time too). The installation is reverse of removal. I measured the tie rod distances when I put the new ends on. The only change I made was that I tied the steering shaft boot down onto the rack so I could install the bolt. I couldn't push the boot up high enough to get the bolt back in. Be sure to install the new power steering line seals that should come with the rack (buy new ones if it doesn't) - the lines are different sizes so you can't mix them up. Torque everything to spec when reinstalling (the cheap Hanes manuals have what you need along with these directions!). It's easiest to install the sway bar brackets when the sub frame is hanging down. Once it's together and running, check the power steering fluid. Get an alignment immediately (I set mine up before I changed the rack).
One last bit of advice, buy the rack with the longer warranty, you don't want to do this twice.
Apr 08, 2012 | 2001 Pontiac Montana
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
I have a mens schwinn midmoor bike that I'm trying to find a rear rack for. Where do I attach the rack at under the seat? Do I need a seat clamp attachment? What size? I'd appreciate any help! :) ...
The most secure and sway-free type would be one that bolts to the bike at at least three points, not simply clamping the seatpost.
Blackburn and Topeak make some nice ones. They mostly bolt to those pre-drilled holes above and behind the rear axle and most say what wheel-size bike they will fit plus they have a range of adjustment (usually via bendable metal braces) for reaching that key third point near the top of the seatstays or brake bridge.
Mar 26, 2011 | Schwinn Midmoor Men's Hybrid Bike
Hi I have just purchased two schwinn link bikes,also two carrying racks for the back. My problem is the bolts that came with the rack are to long on the chain side.Since the holes on the frame are...
Hello melrose.... just remove one of those bolts and take it into any hardware store and they will size it for you and sell you the length you need. Joe
Thanks for choosing Fixya!
Jan 07, 2011 | Cycling
How do you install rear bike rack on a bike with disc brakes?
Depends. If it's a frame with the rear caliper inside the rear triangle the rack will usually bolt right on. If it's a frame with an IS mount caliper hanging off the back of the seatstay you will usually need a to use a longer bolt and a spacer to let the brake and rack share a mounting point. If it's a bike with a post mount brake you will probably have to improvise something. P-clamps can be helpful.
Dec 16, 2010 | Cycling
I have an old hitch mount bike rack : Thule 515-0109 and a Trek women's touring bike. How do I mount the bike on the rack?????
You have to buy a women's bike adaptor, (about $30) and it is a bar that makes the frame like a mens frame. Bike shops sell them.
Jun 01, 2010 | Cycling
2002 pontiac grand am rack and pinion replacement how to
Removing the rack and pinion assembly from a 2002 Pontiac Grand Am Se To get the old rack and pinion off of the car for replacement involves lowering the sub-frame, removing the stabilizer bar, and pulling the rack out from the driver side of the vehicle.
  • Start by lifting or jacking up the car and removing the front wheels. Once the car is safely supported, disconnect both tie rods from the steering knuckles.
  • The rear motor mount sits on top of the cross-member part of the sub-frame, and must be disconnected to allow the sub-frame to drop a few inches. Remove the three bolts attaching it to the center of the sub-frame - one in the back and two in the front near the back of the transmission.
  • Loosen the two bolts holding the front of the sub-frame. Place a scissor jack or bottle jack under the rear of the sub-frame where the bolt for the motor mount was. Remove the two smaller bolts from each side of the rear of the sub-frame (total 4 bolts) and then loosen the two remaining larger bolts holding the rear of the sub-frame (these bolts go through the rear control arm bushings and are very long) until the bolts are only going through the control arm bushing, and not into the chassis. You do not need to remove these completely.
  • Remove the stabilizer links from both sides.
  • Next you must disconnect the steering linkage. This is done easily by lifting up the rubber boot to expose the small bolt holding the linkage. Remove the bolt and pry the linkage upward using a pry tool or screw driver.
  • Near the passenger side of the crossmember, remove the bolt holding the power steering line bracket to the chassis. You may now begin to lower the sub-frame using the jack. The front bolts should have lowered the sub-frame about a half-inch or so, allowing you to lower the back of the sub-frame 3 or 4 inches.
  • With the sub-frame lowered, you can now access the bolts holding the stabilizer bar in place. The right side has a nut screwed onto the top of it holding the power steering lines, remove this first, then remove both bolts. Pry or pull the stabilizer brackets up and out. Remove the stabilizer bar.
  • Now you can get to both of the bolts holding the rack in place. Remove both of these, then begin to slide the rack toward the driver side wheel well until there is no more slack in the power steering lines. At this point you should be able to get to the nuts securing the lines on the rack. Loosen both nuts and be ready with something to cap the ends with. I used part of a plastic bag and a wire to tie it. You can now pull the rack out through the driver side.
  • Be sure to replace the rubber o-rings on the ends of the lines when putting the new rack in. Replace everything in the reverse order. Put your tie rods on the new rack, making sure to count the turns or make a mark or measure to be sure your tie rods end up close to the same length as before.
  • Bleed the power steering system.
Important: Get an alignment! Not only is it dangerous to drive with your steering out of align but it will also grate the tread off your tires in a matter of weeks or even days.
Oct 27, 2009 | 2002 Pontiac Grand Am
Pacific International Pacific Evolution Girls' Mountain Bike (24Inch Wheels) Logo
106 people viewed this question
Top Pacific International Cycling Experts
Nathan
dante
Andy Brown
Andy Brown
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
