Question about Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA
Hook up the system works when on but timer does not move there fore it will not come on or shut off automatic
    Problem Solver:
  • 12 Answers
If the yellow dial is not keeping time first check to see if the motor is wired correctly. If yellow dial is keeping time make sure you have the pins inserted correctly. see the parts list here.
Please see following link for parts list and Instructions
http://sbeelectricandhvac.com/doc_details/124-intermatic-model-r8806p101c-manual.html
Posted on May 23, 2011
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Orbit automatic faucet timer will not shut off
Try to spray with a lube like wd 40. sounds like the mech is hung up with a foreign material. Spray-rinse-reinsert fresh batt.
Jul 29, 2014 | Orbit 2-Dial Hose Faucet Control Timer...
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
Timer runs constantly. Runs cycle then shuts off and shortly later restaRTS.
Posted under GE 15069 countdown timer.
Unknown if this is new timer that is wired wrong or if load has interference, or existing timer that stopped working.
If new timer, then check wiring: This timer is for single-pole application only and requires neutral wire.
http://waterheatertimer.org/GE-timers-and-manuals.html#15067
Then check for line interference by moving timer to different Load, for example ordinary incandescent light bulb.
Make sure slide switch is set to Timer.
Slide switch works as ordinary on-off switch, so see if slide switch works correctly.
If timer stopped working:
Feel timer if it is warm to touch indicating overload or internal timer short.
Timer is rated for 1/2 HP at 120Volts. Check nameplate on motor for HP.
Check for short in line by temporarily replacing timer with on-off switch, and check wire nut connections.
Move timer to different Load, for example ordinary incandescent light bulb.
If timer has gone bad, then return it to Home Depot and swap for different timer.
If load interference is problem, then buy mechanical spring-type countdown timer like Intermatic FD60
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Aug 03, 2011 | GE 60minute Automatic ShutOff Timer Switch...
I am installing the timer for a whole house fan. I hooked red up to load, black to hot and white to neutral per instructions...confirmed with meter....the timer does not seem to work..I can turn on and...
A) GE 15069 image at Amazon
http://www.amazon.com/60-minute-Automatic-Shut-Off-Timer-Switch/dp/B002DNAE7Q
15069 manual
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/In-Wall-15069-Manual-eng.pdf
Manual shows GE 15069 countdown timer is rated up to 1/2 horsepower
Whole house fan is likely 3/4 horsepower >> check nameplate on fan motor.
B) work around:
Hook timer up to a contactor/relay.
Timer turns on 120 volt, 7 watt contactor coil.
Contactor turns on fan motor
http://waterheatertimer.org/H230A.html
Square D contactor at Grainger
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B132?Pid=search
http://www.pexsupply.com/Furnas-Controls-45EG20AF-2-Pole-30-Amp-120V-Contactor
I buy these contactors at local HVAC supply for $15
add a comment if you need help wiring this device.
C) List below shows countdown timers with horsepower rating:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Lutron MA-T51 countdown timer specifically says it cannot be used for motors, which says the electronics inside each device is Load specific
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
Dec 12, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Knob does not automatically turn so dryer does not shut off
Reach inside and clean these sensors so the mini-board can sense the dampness and power that timer motor towards the finish line. 73ce909.jpg
If that don't do it next grab the mini-board, yank it out and clean the corrosion on the contacts. If yours does not have sensors then the system relies on control thermostats to move the timer motor. If your dryer ain't a fancy model then the timer motor is simply shot.
Feb 27, 2010 | Dryers
The rear lights won't shut off when the car is shut off.
the lights you have on are probably the brake lights. you need to check the brake light switch. it is probably stuck in the on position and that would cause the cruise to not function properly because the cruise automatically shuts off when you press the brake pedal.
hope this helps!
Feb 17, 2009 | 2008 Nissan Frontier
Sandisk sansa clip mp3 shuts of and wont turn back on...
You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
player automatically when it is playing for a certain time.
1. Press Menu button to return to the Main Menu.
2. Move to Power and select it.
3. Select Auto Power Off or Sleep.
-Tha Mp3 Doctor
Nov 06, 2008 | SanDisk Sansa Clip MP3 Player
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Logo
162 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
