Question about Kenmore 42926
What does the blinking lights mean when it flashes "F" then "02"?
    Sergeant:
    Champion:
  • 226 Answers
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch
Posted on May 23, 2011
Check engine light flashing check engine soon smell of gas and not running smouth
Check engine light flashing means there is a bad misfire , it flashes to tell you your damaging your catalytic converter . You need to have it check , you don't won't to have to replace the catalytic converter . Can cost up to $1,000.00 . Flashing Check Engine Light CarMD
Feb 03, 2016 | 2004 Cadillac Deville
1996 honda accord wont shift into overdrive
For Automatic transmission problem,click the link below:----Overdrive light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
--------- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Mar 04, 2012 | 1996 Honda Accord
I lost reverse and overdrive is slipping and humming at low speeds on my 4.3L two wheel drive '97 sonoma! Does this mean a whole new rebuilt/swap transmission or can it be something less such as a
Yes it can be transmission issue,as per the problem.In this condition i suggest to you to go through the procedure mentioned in following help links.Click the link below and go through troubleshooting procedure to confirm the problem :-----Engine stumbles and shuts off in forward gear? http://schematicsdiagram.blogspot.com/2012/01/engine-stumbles-and-shuts-off-in.html-----------Transmission problem? http://schematicsdiagram.blogspot.com/2012/01/transmission-problem.html
---------Automatic transmission will not go into high gear? http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
------------Transmission shifting problem on Toyota Land cruiser? http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
---------Transmission Slips out of gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
---------OD light flashing and transmission fluid leaking? http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
-----------Overdrive light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
----------O/D OFF light flashes ? http://technoanswers.blogspot.com/2012/01/od-off-light-flashes-on-ford-explorer.html
---------While going in reverse mode Fuse number 27 blows? http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
---------This will help.Thanks.
Feb 16, 2012 | 1997 GMC Sonoma
What does diagnostic lights mean in dell studio 1535? How do I understand what the problem is by looking at the flashing lights? For instance, what is the problem if mute and volume up lights are blinking...
I have seen questions about the diagnostic codes (volume/mute LEDs) on Dell Studio 1735 1737 laptops where the Mute and Volume up lights stay on while the Volume down Blinks. So far as I can tell, by searching the web, no one has posted the meaning of these lights.
Well here is a link to tell what the light codes mean. If your system has power but is not performing a POST just check if the mute, volume up, and volume down multimedia buttons are lit in a sequence indicating a system problem.
Here is the wesite to explain those POST failure codes.......
http://www.techmonsters.com/DellTraining/bin/Foundation2010/Portables_Foundation_2010/Studio/Studio_1737/1737/general_ts.htm
Dec 08, 2011 | Dell Computers & Internet
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
What does the "O/D off" mean it is blinking on the
I own a 2001 Sephia LS..."The O.D. off" flashing with "check engine light" didn't have a thing to do with an engine problem...it was simply a bad connection in one of the 3 plugs that plug into the back of the instrument cluster!! I removed the cluster, pulled the 3 plugs, cleaned them and put it all back together...No problems since. By the way...mine has 112,000 miles on it
Nov 15, 2010 | 1999 Kia Sephia
02 cbr 600 f4i, red fi light flashes and bike idels high and takes a wile to go back to normal after you rev it
you have a fi fault revmove the seat cowl on the left hand sise you will see the cdi unit (black box with wires going to it) you should see a black conector with two wires going to it bridge the wires with a pice of wire or split pin turn the igntion switch on and count the blinks one long one means ten recored the the blinks and phone a dealer and ask them for the fault code.to reset the the light pull out the bridge and the light should stay on or blink repeted turn off the switch make sure the kill switch is set to run hope this helps
Oct 29, 2009 | 2002 Honda CBR 600 F(4)i
Light is flashing and will not print
dude..u didnt mention printer's make n model nyhow give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
May 08, 2009 | HP DeskJet 930cm InkJet Printer
Washing Machines Logo
109 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
