Question about Nokia N72 Cellular Phone
Cant message on n72
Actually my phone memory is reducing on its own will . it has reduced from 12 mb to 70 kb and thus no operations can be performed. i keep everything on my memory card. so there is nothing i can delete on my phone. wat to do? plz help!
    Problem Solver:
  • 18 Answers
You would have to flash the phone and reload the firmware version to a newer one. connect it to your pc, backup your data, and install the new version of firmware.
this problem has actally occurred because due to some error, your phones memory allocation has been reset so it is showing up with false memory reports.
hope i was able to resolve your issue. good day
Posted on Aug 18, 2008
I have a problem my phone was locked my serial no 356966015852710
Posted on Aug 16, 2008
Low memory nokia e75 My device currently has: 75 MB in use and 13 MB free the rest memory details are: Calender: 32 KB Contacts: 177 KB Messages: 142 B Images: 197 KB Sound...
75 MB in use and 13 MB free the rest memory details are: Calender: 32 KB Contacts: 177 KB Messages: 142 B images: 197 KB Sound files: 0 KB Video files: 0kb Documents: 177 KB MIDP apps: 6 KB SIS apps: 7166 KB Other files: 64 MB
You have given these detail.But actually no need to put this.the only question is which memory status that you are mention here..is it for phone or mmc(Edrive)?anyway here is the trick don't bother for mmc memory you just consider the phone memory.First make backup all the important data like Contacts,messages etc. which is in the phone memory.and try to format by pressing *#7370# and put pin code when ask.
Jul 11, 2011 | Nokia E75 Cell Phone
My nokia 7230 mobile is show 70 mb phone memory in pc.but in my phone approx 12 mb show,and free memory is only 3 mb when i apply 2 mb of themes then my free memory is affected after all ,phone show this...
try to format the cell phone and get a virus check done through any good anti-virus and if it still does not work then please update your software.
Dec 24, 2010 | Nokia 7230 Cell Phone
N72 Nokia Mobile shows phone memory full. 2128 kb free, 3kb calender, 52 kb contacts, 621 kb messages. Then how its possible that memory is full.
Dear, your Primry memory is set to your phone memory. So need to go to messages and then in options select memory settings and then select your memory card in memory settings. Don't worry only one time you have to do it. Thanks
Apr 13, 2010 | Nokia N72 Cellular Phone
My operating system is windows 98, i recently upgraded my memory card from i gigabyte to 2 gigs, but every time i boot my computer there is an error message low in memory, the question is; how can i boot...
CAUSE:
The Windows 32-bit protected-mode cache driver (Vcache) determines the maximum cache size based on the amount of RAM that is present when Windows starts. Vcache then reserves enough memory addresses to permit it to access a cache of the maximum size so that it can increase the cache to that size if needed. These addresses are allocated in a range of virtual addresses from 0xC0000000 through 0xFFFFFFFF (3 to 4 gigabytes) known as the system arena.
On computers with large amounts of RAM, the maximum cache size can be large enough that Vcache consumes all of the addresses in the system arena, leaving no virtual memory addresses available for other functions such as opening an MS-DOS prompt (creating a new virtual machine).
WHAT CAN U DO?
To work around this problem, use one of the following methods:
  • Use the MaxFileCache setting in the System.ini file to reduce the maximum amount of memory that Vcache uses to 512 megabytes (524,288 KB) or less. For additional information about how to use the MaxFileCache setting, click the article number below to view the article in the Microsoft Knowledge Base: 108079 (http://support.microsoft.com/kb/108079/EN-US/ ) 32-Bit File Access Maximum Cache Size
  • Use the System Configuration utility to limit the amount of memory that Windows uses to 512 megabytes (MB) or less.For additional information about how to use the System Configuration utility, click the article number below to view the article in the Microsoft Knowledge Base: 181966 (http://support.microsoft.com/kb/181966/EN-US/ ) System Configuration Utility Advanced Troubleshooting Settings
  • Reduce the amount of memory that is installed in your computer to 512 MB or less.
Feb 07, 2010 | Computers & Internet
My nokia n72 keeps on saying memory full delete some files...I have nothing on my memory card yet. What am I supposed to do to fix this...Please HELP!!!!!!!!!!!!
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
May 02, 2009 | Nokia N72 Cellular Phone
My phone's(nokia n72) instlled memory keep on decreasing automatically i use the memory of memory card but still it happens. now the installed memory is reduced upto 20kb nd i can't even open my...
are you sure you havent turned your video capture setting to "unlimited"? because if that is the case, all your memory will be consumed to the last byte while recording.... and try to scan an antivirus just to wrap things up
Feb 25, 2009 | Nokia N72 Cellular Phone
How to reduce phone memory
the best thing to do is back-up your files and reformat the memory card.. tnx
Feb 16, 2009 | Nokia N72 Cellular Phone
Error msg "Not enough memory to perform operation. Delete some data"
yes i do have the same problem . pls find a solution to it.....
Aug 10, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
