Question about Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with
My dual flush persuade started hissing after a flush is complete. Is the water level too high or is it something else?
5 Suggested Answers
  • 297 Answers
SOURCE: toilet flushing sytem
your chain on your flapper is to long,adjust to proper hight.
Posted on Jul 15, 2009
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 323 Answers
SOURCE: I'm about to install a kohler
Are you talking about the slot where the two screws hold the base down to the floor?
If so, that is called a closet flange. You will need to pick one up at Home Depot or Lowes. There are various kinds. If your floor is a concrete pad then you may have to get one that just slides down inside your waste pipe. It can be glued in. If you are upstairs and have a wooden sub floor you can get one with treated deck screws to screw into the floor.
If you have a digital camera, tale close up pictures of the waste site and take them to the store and show them to someone who works in the department. He will know what you need.
Posted on Nov 05, 2009
  • 159 Answers
SOURCE: i have a Kohler dual flush and it doesnt seem to
order a water pump. so the preasure of the water can suppy the requirements pressure of your water closet
Posted on Jun 26, 2010
I have both a dual flush and a conventional high eff. toilet. the water level on both are set on maximum. but the dual flush won't flush toilet paper in a single fluh. can i change out the complet
Why do you want to change it out just because it doesn't take paper out ? The problem is in your trap. Don't change it unless you just want to. I don't think you can change it over anyway due to design differences.
Feb 23, 2013 | Home
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
I can see water trickeling on the bottom of the overflow tube. Already replaced gasket and removed the fill tube. Very slow, about every 20 min. the fill valve kicks on for about 5 sec.
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
Aug 23, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Water level in bowl is too l;ow
There is a float in the back of the tank. It needs adjusted. I will explain more if you would like.
Jan 26, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
What is the problem when water is running on a dual flush toilet
water level set to high push botton rods not ajusted rite 5 year warranty on flush valve
1-800-459-4409 service and parts
Jan 21, 2011 | Toto Aquia II Dual Flush Toilet
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
Sep 08, 2010 | Caroma 270W-RF Reflection Round Front...
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Mar 01, 2010 | Home
Kohler Persuade Two-Piece Elongated Toilet with Dual Flush Technology, with Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
