Question about Kenmore Dryers
Kenmore 700 series dryer; quit operating during cycle; will not restart; has power to terminal block; any suggestions?
    President:
  • 3,074 Answers
The belt may have broken:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
here is another website, Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on May 23, 2011
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
My dryer does not get hot anymore
The thermal cut-off located on the heater housing is likely blown. It blows if there's an issue with clogged ducts and/or faulty high-limit thermostat. These components including the cycling thermostat on the blower housing are wired in series with the heating element and power to the heating element is terminated if one of them, usually the thermal cut-off, cuts or blows open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 28, 2011 | Kenmore 700 7973 Dryer
Kenmore 90 series electric dryer qiuet pak 1 101649022200 the lights are on when you open the dryer but the dryer itself will not turn on or do anything!
There's thermal fuse on the blower that blows when the cycling thermostat malfunctions or the lint/vent duct are blocked. This thermal fuse is wired in series with the dryer motor and if it blows, power to the motor is terminated causing the dryer not to start and no dryer function works. Check to make sure that the lint filter is always clean and the vents are clear. Click on the link below for the detailed troubleshooting of the dryer, particularly the thermal fuse, when it doesn't start.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 09, 2011 | Dryers
Kenmore dryer has no power. the electricity going to the dryer is fine. any advice?
check the cord on the back of the dryer itself as sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced. Maybe the door switch also. Good Luck Tim
Dec 24, 2010 | Kenmore 700 7973 Dryer
Dryer will not restart
Sadly, the thermostats in your dryer control the heating circuit only. There is a thermal fuse that will not allow the dryer to start, but it's one time only and cooling down will have no effect.
The scenario you describe is the motor cutting out on it's internal overload. When it gets to the point where it cuts out on the overload mid cycle, it's unlikely cleaning lint will solve the problem. You might want a tech to come out and verify that the motor needs to be replaced.
Another possibility is o loose connection in the power source. This could be at the dryer terminal block, in the dryer cord receptacle, or at the circuit breaker.
May 04, 2009 | Dryers
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Replacing a defective Terminal Block - Kenmore Dryer
If there are any lose wires connected to the dryer terminal block and there is any sign of current draw like black around it or if it just looks bad in general then yes it does pose a threat of a fire hazard or electrical hazard like shocking you when u touch the frame. There is a terminal block you can buy for it visit any part place with the model number and they can help you out hope this helps
Jan 08, 2007 | Kenmore 64892 Electric Dryer
Dryers Logo
231 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
