Question about Hunter (25417) Ceiling Fan
Need help with the wiring for hunter ceiling fan after removing wattage governor. how to reconnect wires to get the light to work.
  • 3,640 Answers
It should be white wire to white wire and black wire to red wire. black and red are always the hot wire. but turn off power before working on it, or it will be a shocking experiance. if only white and black wire, white to white and black to black. this should do it. have a good day !
Posted on Jun 08, 2011
Hunter Fan. Lights blinking on and off. I have read that it is the light governor and I should remove it and wire direct. I need more detail. Where is the light governor and how do I wire it...
the watt governor is inside of light assembly. it is a square black box. take this out and hook it direct, white wire to white wire, black wire to red wire. and this should solve the blinking lights. good-day!
Aug 10, 2011 | Hunter 22460 52'' The Astoria Brushed...
We had the Hunter fan installed in April and have been very pleased with its performance. About a week ago whenever you turn on the fan light it flickers nonstop. Can you help me?
this is caused by the watt governor or the black box in fan to the lights. remove the watt governor and wire the lights directly. when removed, hook white wire to white wire, and black wire to red wire. black and red wires are always the hot wires. governor part number- 98480-02, have a good day !!
Jun 19, 2011 | Hunter (25417) Ceiling Fan
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
The light on my hunter ceiling fan flashes on and off when I turn it on. I have a model 21421-530 Type 2. Any ideas what might cause this? Ceiling fan works fine on all 3 settings, so I don't think it's...
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
Jan 19, 2011 | Hunter 52" Ceiling Fan With Light And...
Hunter 'lodge' ceiling fan w/light: all switches 'on' and light blinks???? what do I do to correct problem?
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
Dec 19, 2010 | Hunter 52" Ceiling Fan With Light And...
When we turn on the light, the light blinks on and off really fast like a strobe light. I have checked and all the connections are correct and secure.
there is a watt governor on inside for lights. remove this governor and wire direct for lights. this should fix problem. have a good day !!
Nov 14, 2010 | Hunter 52" Ceiling Fan With Light And...
I have 2 of the same Hunter Douglass ceiling fans with double light kits in my living room. Yesterday one of them started blinking the lights constantly when I tried to turn on just the lower bowl light....
if problems with blinking lights, remove watt governor on inside of fan for the lights.its a black box,white to white wire and black to red wire. and wire it direct without watt governor or black box. this should fix the problem. the part # 98480-02 for watt governor. they installed watt governors on ceiling fans to reduce light wattage.
Sep 19, 2010 | Hunter Fan/Light Wall Mount Control 27186
4 month old Hunter 52". After install, when you turned on the tulip lights that came with it, they would come on bright, then dim about 20%. Recently, when the light was turned on, they would blink...
Your problem is you are using too much wattage for your fan. You can solve this one of two ways. Put in lower wattage light bulbs (per your manufacturer recommendations) The other is to remove the wattage governor. There should be 3 screws holding your light assembly on. Remove these screws then disconnect the white rectangular plug in connector (this is what connects the fan wiring to the light assembly wiring). At this point you should be free to take the light assembly to a table. Follow the light pull chain wires from inside. One of these wires will lead to a black box that has 1 black wire, 1 red wire and 2 white wires. Remove this black box...this is the wattage governor. Remove by cutting the 2 white wires as close to the box as you can, peel back the insulation and use a wire nut to connect the 2 white wires together. Remove the wire nut on the black wire from the switch to this black box. Now you have one red wire left and your bare black wire from the switch. You will remove the red wire and put the bare black wire from the switch in it's place. Throw the wattage regulator in the trash and install you light assembly back to the fan. It will no longer blink but you should still use the recommended wattage light bulbs to prevent overheating.
Aug 19, 2010 | Hunter (25417) Ceiling Fan
Hunter (25417) Ceiling Fan Logo
180 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
