Question about Danby DPAC90061 Portable Air Conditioner
I have a Danby DPAC90061 portable air condition unit (9000 btu) and of the dual hose has ripped. What is the actual diameter size of the hose and where can i purchase it in Ft. Lauderdale?
Illeagle
  • 525 Answers
SOURCE: installation
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Posted on Jun 03, 2008
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
  • 230 Answers
SOURCE: Danby PORTABLE Air Conditioner model
The base needs to be dumped regularly. The air conditioner sweats water during operation and the pan collects it. Your manual should give you the procedure on how this is done. In some cases there is a hose attached to the drain pan so that you can direct the drainage to a more conventional drain location.
Posted on Jun 27, 2008
  • 230 Answers
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
bestdarngood
  • 3037 Answers
SOURCE: In Dry and Air Condition
It is leaking water correct? Check your hose for clogs or a crack, follow it up and find where it is exactly coming from. If you need a part replaced, let me know and I can find you a replacement. If you have questions about accessing parts, let me know but the outer panel should be held together with simple screws.
Posted on Aug 13, 2008
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
My danby model dpac90061 plugs in and wont turn on
Hi There,
I have just spoken to one of our technicians and he said that if the there is a red blinking light that usually means that the bucket or drainage system is full. If that is not the issue, it could be a malfunction in the touch pad. If the issue is not the bucket, please contact our customer service department regarding repair. (1-800-26-Danby) We are available Monday to Friday from 8:30am to 4pm EST.
Thanks!
Jul 18, 2012 | Danby DPAC90061 Portable Air Conditioner
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
My Danby DPAC90061 cools but does not deshumidify. How can I fix it? First year, I had to empty the tank. Last year, there was no water buildup.
It sounds like you may have a very small refrigerant leak and the unit is not even cooling like it should, but is still colling enough to keep you cool in the room...does it seem like it runs more then it used too...??? the compressor that is, not the fan...
heatman101
Apr 21, 2010 | Danby DPAC90061 Portable Air Conditioner
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally...
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
Installation
Jun 03, 2008 | Danby 7,000 BTU Portable Air Conditioner -...
Danby DPAC90061 Portable Air Conditioner Logo
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
