Question about Garden
I have a Yardman 6.5 OHV Intek 21" lawnmower and all of a sudden it started idling really high and I can't find an idle adjuster, is there one and if so where? thanks for any help you can give me
I smacked the front of the mower into my boat trailer, and it shut down and would not stay running.. Idle was too low. Finally found the idle adjust and fixed it right away.The idle adjust is a piece of metal that is bent down, over the edge on the throttle linkage. It hangs over just above and to the right of the gas "bulb"...that thing you have to press before starting the mower. It is 1/8 " wide and about an inch long. comes off the linkage that is connected to the throttle cable assembly. As it hangs over the edge of the assembly , it controls the idle speed. bend it one way or the other to adjust.It is kind of hard to describe. Hope this helps.
Posted on Jun 24, 2011
Mowing at mid throttle, suddenly the engine started over revving. Acts like governor isn't working. Every time I try to restart it instantly starts to over rev.
According to Amie Taylor on http://homeguides.sfgate.com/lawnmower-revs-up-down-100220.html "Airflow Issues A lawnmower that hunts and surges may be experiencing something as simple as an airflow issue. If the air that the engine requires to run is blocked, especially sporadically, it can cause the engine to slow down. When the blockage moves or clears, the engine may suddenly rev up in response. To fix this type of problem, check the air filter to ensure that it's not clogged with dirt and debris. Check the vented gas cap as well. Both issues can cause reduced or sporadic air flow, and clearing them will fix the problem.
Spark Plug Problems Another problem that can cause revving and dying of a lawnmower engine is a faulty or poorly adjusted spark plug. Check the spark plug to see if the wire is connected to it firmly and not wobbling about. If it is connected correctly, remove the spark plug to see if it's covered with corrosion. If so, a simple scrubbing with a wire brush can restore it to working order. If necessary, replace the spark plug with a new one. Check the spark plug gap with a spark plug gauge to ensure that it's adjusted to the proper setting recommended in your owner's manual.
Carburetor Adjustment A carburetor that's incorrectly adjusted is a common cause of poor engine idling that results in hunting and surging. Fortunately, most lawnmowers have two screws that allow you to adjust the carburetor yourself. One screw controls the idle speed while the other adjusts the idle mixture. Check the manual if you're unsure of the location of the idle adjustment screws. Start the mower and allow it to run for 5 minutes. Then slowly adjust the screws tighter or looser in turn until the mower runs and idles smoothly.
Fuel Problems A particularly simple fix that can be at the bottom of many lawnmower idling problems is old or contaminated fuel. If the fuel has been left in the mower while it was stored over the winter or while the mower has remained unused, drain it and replace it with fresh fuel. If you have gas-powered blowers and trimmers that use a mixture of 2-cycle oil and gasoline, check to see that you've not placed that mixture in the lawnmower inadvertently."
May 10, 2015 | Garden
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
21 INCH YARDMAN IDLE PROBLEM
If it's a constant speed engine with no adjustement for idle or a variable speed engine with no adjustement screw for idle , then it needs a carburator overhaull . If not adjust the idle scew , engine hot .
Aug 29, 2012 | Garden
What is high idle?
When a car is idling it is at rest.The idle setting refers to the engine revolutions or 'revs'.If the setting is increased so that the 'revs' are greater,the engine will not stall at rest.This is 'high idle'!
May 16, 2012 | Cars & Trucks
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Engine is surging when in idle
clean out the carburetor jets re-assemble then adjust fuel mixture screw until it runs correctly
Apr 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
239 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
