Question about Frigidaire Model: PHSC39EHSS
I have a Frigidaire model PHSC39EESS5. The freezer seems to maintain temperature fine, but the refrigerator is too warm. I checked the cooling coils and they are iced up. If I melt the ice, the refrigerator works fine for a while and then warms up again. When I checked, the coils were iced up again. I can't find anything in the owner's manual except a suggestion to turn the temperature down for the refrigerator section, which doesn't work.
ngfam1
  • 639 Answers
SOURCE: frigidaire refrigerator
Friend,
ngfam1 At your service!
Sounds like your thermostat is malfunctioning.
Do not let it keep going like this without service or it will burn out the compressor soon by running non stop.
How old is the fridge????
now that's expensive and not worth investing in if the fridge is 10 years old or more the new refrigerates use much less power and can change your electric bill for the better !
Below I referred you to a great service nation wide!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
carldc3
  • 82 Answers
SOURCE: fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Posted on Jan 05, 2009
SOURCE: Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: ice maker on frigidaire not working, changed
how cold is the freezer?
Posted on Feb 27, 2009
Why on my model FRS6LR5EW3 freezer side is working maintains ice but fresh food side is not working, no light, no fan??
Good Morning Friend,
I understand the freezer portion is working on your Frigidaire refrigerator, model# FRS6LR5EW3, but your refrigerator does not seem to be as cool as it should, due to the fan not working. I also see that the light is not working, even after changing it out. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the light is on. Also, listen for the fan to run and give the refrigerator portion of your appliance 24 hours to stabilize at the set temperatures. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire Refrigerators
Freezer is running at a warm temp- cannot maintain a constant temp of -1. Refrigerator is fine and working properly. Anything I can do before calling a repair mn?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | Jenn-Air JS48SEFXDA Stainless Steel Side...
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
FRS2625H - frigidaire gallery professional freezer is maintaining temperature but refrigerator is not - barely cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Frigidaire FRS26H5AS Side by Side...
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
Refrigerator gets too warm, then too cold, back and forth...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 26, 2009 | Frigidaire FRT21H8 Top Freezer...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
MY HOTPOINT HAS A SIMULAR PROBLEM......IT SOUNDS LIKE YOUR CIRCUIT BOARD IS BROKEN...THERE ARE NOT THAT MANT PARTS TO A FRIDGE/FREEZER SO THE LIKELY HOOD IS CIRCUIT BOARD OR MOTOR.....HOPE THIS HELPS
Dec 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Open Questions:
Frigidaire Model: PHSC39EHSS Logo
171 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
