Question about Garden
I just got a refurbished pressure washer and after a week of it working i went to use it today and it works there is just no pressure from the knozzle can u help ?
  • 2,428 Answers
Im not sure you have replaced on the mechine and you say it worked for a weak so it sounds like a new problem . But i owen a few powerwashers and wash houses as part of my bussiness. The most likely things that will stop the pressure are eighter the valves in the water pump witch under the caps on the pump the cages are sometimes made out of plastic and peices of the cage can break of and stop the valve to not seal all it takes is one of them but if you remove the peice the mechine will work again . However it could be what is called the unloader valve . This is a valve located under the water pressure control knob it adjusts the pressure at the tip but also allows the water inside the water pump to recurilate in side the pump when the trigger is not pulled so the mechine won't over build inside the pump if its stuck in recuriculate you will have no pressure at the tip . Most of the unloader are not rebuildable but i fine if you remove them and turn the knob while spraying WD40 into them most of the time you can free them by turning the pressure control knob You have to play with it good luck
Posted on May 23, 2011
Washer worked fine all week. Today. I went to use it and I pulled the knob out to start the machine and nothing happened. Just the little red light came on. It is a Maytag top loading model LAT9734AAE
door switch look where lid closes and depresses closed swich that swich has 2 wires on it un plugg them tape them together hit start it should work
Jan 24, 2011 | Maytag Washing Machines
Got wet
Of Course it wont -.-... It went through the washer! Nothing works once it goes through the washer...Believe me i know...-.- My cell went through the washer...
Sep 30, 2009 | RCA M4204 MP3 Player
Buttons on Kenmore HE3 washer not working. Can only get delicate cycle to work and options on right hand side (water temp, spin speed, etc) not working.
I have the same problem. It started a few weeks ago. I did get it to work for a while by unplugging from the wall outlet. When you plug back in, you can choose one clcle and it will work. I repeated this 3 times and it went back to normal for 3 weeks until today. Trying to find a true permanent fix. unplugging and replugging resets something, will work temporarily
Jul 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My voyager wont charge its brand new... only three weeks old and ive chaarged it before but now today i went to charge it and it wont work
If you have already tried using another charger, then the charging port inside your phone is probably either broken or bent. I wouldn't suggest trying anything to unbend it or fix it yourself; I would go up to the store if I were you. I had the similar problem, and I just got my refurbished (4th Voyager) in the mail today. But my most recent old phone did the same thing, and I had to get it replaced; I hope I helped some!
Jun 07, 2009 | LG VOYAGER VX10000 Cellular Phone
Worked well, then blew the fuse.
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Mar 10, 2009 | Karcher K2.26 Electric Power Washer
Nailer leaking air
Same situation here with the same model.  Turned out to be lack of pressure coming from the air compressor.  I turned up the pressure a little and things went fine afterwards.
Nov 23, 2008 | Dewalt D51825 Heavy Duty 31 Degree Clipped...
Jammed door
turn it off all the way and its automatic timer will release after about 3mins
Nov 06, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
