Question about Maytag SAV571EEWW Washer
Maytag top washer. Leaking for side and back during washing cycle. Model LAT9706AAE
  • 1 more comment
  • sosusie99 May 23, 2011
    My Maytag washer model is LAT9706AAE . What part number would that be for a water injector?
    Also it doesn't leak if I run a cycle with loading clothes.
  • sosusie99 May 26, 2011
    I found the leak coming from my stem seal. I need the part number to for seal.
    The leak is coming from stem seal. I need part number to replace the seal.
  • 4,323 Answers
Hi
If the washer fills and drains fine then the issue is with the water level switch that is bad and should be replaced. . If the water inlet valve has gone bad it won't be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won't tell the water to shut off and the machine will overflow as this switch will sense the water level in the tub. Please check this diagram....part#13 is the water level switch (part no 22001777). Hope this helps...please post back for further assistance.
Daniel
Posted on May 23, 2011
  • 17,970 Answers
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
these parts for this machine are available, more than likely it the water injector thats leaking. if you look on the bottom of the front panel at an angle you will see 2 phillip head screws remove them and pull the front panel out at the bottom and it will release at the top clips. put it asside and look on the left side near the top and fill machine and if the water is cooming from ther its the injector assembly, click here to bring up the injector parts you will need to replace parts 444984 and 400646 to repair this.
Hope this helps.
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Maytag Washing Machine Model LAT9706AAE Won't
Check at the back of it,the rubber belt may have become loose or sometimes slips off it course and may need re-fixing....
Jun 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
NO HOT WATER MAYTAG WASHER Model # LAT9706AAE
replace the dual inlet valve located in the rear of the machine. have included a link to help you...you can also purchase the part from the same link. http://www.partselect.com/repair.aspx?appliance=washer&part=replace-water-valve
Jun 22, 2009 | Washing Machines
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Large leak during wash cycle---Maytag - model LAT9520AAE top load washer
hey guys i guess this is not a uncommon problem. I have a commercial washer about 4 years old that get moderate service at a rental of mine and it is leaking from the tub as well. I hope to fix the problem because the new machines are very expensive.
Mar 22, 2007 | Maytag LAT3600A Top Load Washer
Maytag SAV571EEWW Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
