Question about Kenmore Top Freezer Refrigerator
Water is pooling in the bottom of the refrig - under the veg/fruit bins and then draining out onto the floor
  • 4,066 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Posted on May 23, 2011
Ice build up under vegetable and fruit bins
Pull the bins out. Just above them is a channel with a hole in the middle. Push a drinking straw in the hole to clear the drain. The water will drain away instead of dripping under the veg bins.
May 04, 2017 | Refrigerators
I have a frigidaire refrig. Water collects under the fruit and veg bins. Any ideas why and what I can do would be helpful. It is not coming from the ice maker as it was doing this well before I put the...
Hi Erica, I am happy to assist you. I understand that water is collecting in the bins. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator bins. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 16, 2013 | Frigidaire Refrigerators
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
Not draining properly,water under veg. bins
Pull the veg. bin draws out and you'll see a hole that could be clogged with food or frozen water. First, clear away food if there is any. Then, pour boiling water into the drain and watch the bottom of the unit where it should be draining into a pan which will evaporate from the heat of the compressor.
Sep 27, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Water is pooling, on the inside, at the bottom of the refrigerator, under the veggie/fruit drawers. After about 5 days, it spills out onto the floor.
hi , i can help you with that.
open the freezer back wall after taking all things from your freezer out.
on the bottom center of the freezer back wall there is a drain hole,
defrost all the ice with hair dryer and wipe it with a towel.
this hole should be free all the way to the drain pan next the compressor.
clean it with hot water and a pump...
thats all :) let me know if you need any more help...
Jan 11, 2010 | Refrigerators
Magic Chef CTB1722 refrigerator leaking water from inside fridge. The water pools under the fruit and veggie bins and leaks onto the floor.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 12, 2009 | Refrigerators
Water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Apr 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
