Question about Nintendo 64 Console
How do I connect the controllers to the game system?
  • 23 Answers
Align the end of the controller plug to the slot in the console and put it in. make sure the flat part and the round part of the controller plug and the console slot are aligned.
Posted on May 23, 2011
Controller comes on but want connect to system
Have you tried the sync/pair buttons on both the controller AND the 360? (be sure to hold the buttons until the lights spin)
Mar 26, 2014 | Microsoft Xbox 360 Wireless Controller
How do I connect theintec controller to the ps3
Jessica, assuming the intec controller you have is wireless, there are 3 ways to connect ANY controller to a game system. Wired, wireless(bluetooth) or wireless USB. If it is a bluetooth, then you will have to pair it with your system. to do this, you have to go into your settings, then manage bluetooth devices, and add new. If it is like the intec I have, it comes with a USB dongle that MUST be inserted for the controller to work. It is automatic. Just plug it into the system, then turn on the controller. Hope this helps, good luck.
Apr 05, 2013 | Video Game Consoles & Games
How and where do you connect the mat from active life explorer game? It is a wii game that comes with a mat. I am unable to see where the mat connects to the system or remote
Open the door on the left of the Wii Controller. there are four ports for Game Cube Controllers, and you use the one closest to the front.
Jan 08, 2011 | Video Game Consoles & Games
When I turn on my snes, the screen just goes black.
  • Blank Screen
    1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
    2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
    3. Make sure the system has power. If not, go to the No Power Light instructions.
    4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
      Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
    5. There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
    If the above troubleshooting doesn't fix the problem, click here.
  • Other Screen Problems
    1. Make sure you are using only licensed accessories with your system.
      We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
    2. Check all of the system connections to verify that they are firm and correct.
      • For AV connections
        Remove the AV cables and reinsert them with a slight twisting motion
      • For RF connections
        Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
    3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
      Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
    4. Slide the Power Switch on the Control Deck to the ON position.
    If the above troubleshooting doesn't fix the problem, see below.
Sep 16, 2010 | Nintendo Super NES Console
My super nintendo isn't working. It keeps saying i have know signal, yet it worked fine yesterday. i'm on the right channel and everything is plugged in.
    4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
  • Unlicensed products are not fully compatible with our systems and may not work correctly.
  • Check all of the system connections to verify that they are firm and correct.
  • Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
  • Slide the Power Switch on the Control Deck to the ON position.
  • If the above troubleshooting doesn't fix the problem, see below.
click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Aug 27, 2010 | Nintendo Super NES Console
Xbox wont connect to controller
something is wrong with your xbox controller coniction to your system
Oct 07, 2009 | Microsoft Xbox 360 Pro System Console
Game console having wire trouble connecting to controller?
Most likely the controller port is bad on your system and you need it repair or a replaced system. There are also 3 different licensed versions of sega genesis so each one is different to repair.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 02, 2009 | Sega Genesis Console
Plays films, won't play games
this is what u do! you connect your control direct to your ps3. and then you hold the power button for 5 seconds!! the system will turn on!!!remove your finger for a second and hold the power button till you hear 2beeps then remove your finger and the system will shut off!! this is a manuel reset!!! the system will turn back on!! asking u to connect your controller!! you already have it connected. then it will give you about 6 options!! you will choose RESTORE FILES!!! your system will check for your system defaults!! then it will tell you that you have corrupted files!! and proceed with it!!! it will fix if you have problems with your controls,if it doesnt play games,blue ray,if it freeze, system shutting off,icon problems,only playing sertting games or movies!!! if you have problems or any question feel free to ask!! i know is fustrating!!! i did some research and this is what another expert said to do
Feb 22, 2009 | Sony Playstation 3 (PS3) Console
Wireless Connection
If you havent allready you need to press the systems sync button before the controllers sync button. They need to be pressed within 10 secs of each other and the system first.
Oct 28, 2007 | Microsoft Xbox 360 Console
Nintendo 64 Console Logo
21 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
