Question about Canon CanoScan N676U Flatbed Scanner
Can i get this scanner working with Windows 7?
  • 30 Answers
As per Windows 7 Compatibility Center, Canon CanoScan N676U Flatbed Scanner is not compatible with Windows 7.
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=Canon%20CanoScan%20N676U%20Scanner&v=Canon&uid=&pf=1&pi=0&c=Printers%20%26%20Scanners&sc=Scanners&os=32-bit
Posted on May 23, 2011
    Problem Solver:
  • 19 Answers
I had this problem but I got it working but accident. I had to reinstall Windows 7 because I downloaded some software it it did something to my computer so I had to reinstall. I already downloaded the driver from Canon so I just installed it first on to my computer and windows 7 found the driver and my scanner worked. The only time that it doesn't work is if you install everything else first and then the scanner it will not find it for some reason. Backup your computer first and then reinstall Windows 7 from bootup. Setup F2 if you need up please contact me Why play for software like Vuescan when you can do this!!
Posted on Jun 21, 2013
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
Jun 11, 2015 | PANDIGITAL Office Equipment & Supplies
Plz help to get my scanner work.............. BENQ 5000B Scanner For Windows 7 32-bit
Hi ,
You need to use the install cd that came with your unit but probably it won't run under Windows 7 .
The only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Wish you good luck , otherwise you will need to purchase a compatible unit .
Regards .
Dec 14, 2014 | BenQ Office Equipment & Supplies
Getting Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter with an LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE
Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter works just fine I use it every day. The key is to use a third party scanner software called Vue Scan 9.0.57 and using the following start-up procedure so Windows 7 can find the scanner on the SCSI controller. First open windows device manager, then turn on scanner, immediately right mouse click in device manager and select scan for new devices. Windows 7 will immediately find the scanner. It seems that windows will only see the scanner through the SCSI interface during the scanners startup sequence. It has been a while but I believe this works with Mira Scan V4.03 as well.
Sep 22, 2011 | Acer ScanPremio 1220ST Flatbed Scanner
My canon scanner model LiDE 20, 30 not working in windows 7 home premium software please guide me immediately
If you cannot download a Windows 7 scanner driver from the Canon WEB site, then the Vista scanner driver may work with Windows 7.
Aug 22, 2011 | Canon LIDE20 Flatbed Scanner
I can't install may scanner on windows 7 64bit
If you just got a new computer that happens to be windows 7 64 bit, and you've had this scanner for some time. That would be the reason why the scanner won't install, as the disc that came with it is out of date. I checked Canon's driver website if you (canon.com > support > selected your model > drivers and support) and it looks like there are no windows 7 64 bit drivers available. However there are two things you can try.
http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_3200f#DriversAndSoftware Go to that site, and download + install the windows 7 drivers, if they don't work you can use the windows Vista 64 bit drivers. Vista drivers and 7 drivers operate very similarly, so if the regular 7 drivers do not work, once again find where it says Vista x64.
Mar 03, 2011 | Canon CanoScan 3200F Flatbed Scanner
I'm trying to install my scanner on my PC, I have windows 7
From what i can see there is no driver for vista or windows 7 as that is an old scanner.
You can try a program called VueScan which basically supports a bunch of old scanners so they work with current versions of windows. They have a free trial (So you can confirm that it works). If you want to use for free I believe you can but it embeds images over your scans so most people dont like that. I think it is $40 to unlock it.
You can download VueScan here.... http://www.hamrick.com/
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 01, 2011 | AcerScan 640BU Flatbed Scanner
I have ASTRA 3400 scanner, will it work with Windows 7 home premium?
UMax (the manufacturer) noted that there are no drivers for this scanner to work with Vista or Windows 7- however you may be able to get the scanner to work if Windows 7 has a built in driver- likelihood is not very good however.
Oct 03, 2010 | Umax Astra 3400 Flatbed Scanner
I need a driver for my Canon N650u that is compatable for windows 7, 64 bit. where do I find one. This is a perfectly good scanner but it will not work with windows 7
Unfortunately you will not be able to use this scanner with Windows 7. It is not supported
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Canon%20CanoScan%20N650U%20Scanner&v=Canon&uid=&pf=0&pi=0&s=Canon%20N650u&os=32-bit
If Canon doesn't write drivers for this scanner for Windows 7 no one else ever will.
Robert from Blitware
Jun 15, 2010 | Canon CanoScan N650U Flatbed Scanner
CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Sep 17, 2009 | Canon CanoScan N1220U Flatbed Scanner
Driver suitable for CP-HR7X Slim Scanner to work in Windows 7
I can not find driver suitable for scanner CP-HR7X to work in Windows 7 too. I am from Russia.
May 27, 2009 | Genius ColorPage HR7X Slim Flatbed Scanner
Canon CanoScan N676U Flatbed Scanner Logo
740 people viewed this question
old marine
old marine
