Question about Troy bilt 4cycle Backpack Blower 32cc
The start cord on the leaf blower won't pull out more than a few inches. Why is this?
  • 577 Answers
Pull your spasrk plug out and see if it pulls over then, cylinder might be fullof gas causing hydro lock condition,if so pullit till cylinder dries out then re-install plug and try starting. if all is good check your fuel cap to make sure the vent is working! If it's not venting this causes vacumn that pull fuel out of tank to cylinder after it is shut off...........Good Luck 2StrokeJim
l
Posted on May 23, 2011
Pull Cord has stripped and won't recoil. Can this be repaired?
Stripped? Maybe the recoil Spring just broke. Easy repair, sometimes you can just re-bend the 'Stop' on the old Spring
Nov 09, 2014 | Garden
Snowblower won t start. pull cord too tight
How long has it setup? Could be varnished up, maybe broken ring, damaged needle bearings. Remove muffler an try to spray some cleaner or fuel in port to free it.
Mar 13, 2014 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
Why is the electrical wire so short
Don't add an extention cord to an extention cord! Buy a 100' 14/4 extension cord and tie the end to the fence so it won't come un plugged.
If the plug keeps popping out of the short cord at the blower,wrap the cord around the handle to prevent disconnection.
Nov 18, 2012 | Ryobi 200mph Leaf Blower & Vacuum Mulcher...
Husqvarna leaf blower won"t start,changed the plug and gas,now what
As you pull the cord do you feel a thud thud? if not you don't have compresion. However take the carb apart and clean it with carb cleaner it only takes one small peice of **** to cause trouble.Dennis
Nov 06, 2012 | Husqvarna 28CC Handheld BlowerVac
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
Pull start cord won't rewind model no RLT30CET curved shaft electric start
There is a spring there you don't need to buy one use the old one.. If you need one go online give them model number have in two days.... Good luck..
Sep 15, 2012 | Garden
Husqvarna blower #125BT won't fire over, has spark.
I have seen some issues with these machines shearing the flywheel key ( it is an alloy key part of the flywheel ) if the key has sheared it will knock the timing out and will now require a new flywheel.
Jul 07, 2012 | Garden
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Troy bilt 4cycle Backpack Blower 32cc Logo
281 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
