I have a AK080V small flip down television and the sound on the t.v does not work.
Flip down TV screen out
the cabel running through the hinges has issue, need to open the hinges and chk.
Jul 21, 2008 | Sony ICF-CD555TV 7 in. Portable Television
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
Where to buy replacement screen for tft lcd 8
Contact the authorised service center for your brand TV, to get an orginal one.
May 05, 2012 | Televison & Video
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
2003 dodge truck won't start -security light blinks on dash-everything is locked down
pretty vague, but you should find a button or a small switch under dash area drivers side probably. Turn the key on flip the switch or push the button, the alarm should then let you start the car. sounds like the siren isn't working
Aug 28, 2009 | Vehicle Parts & Accessories
Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
How to flip down the back seat
the rear seat dosent flip down in this model just the small opening behind the arm rest opens . to allow you to ccarry snow skis and such.
Apr 06, 2009 | 2003 Acura 3.2TL
No Sound, Speakers Don't Work
audio board is burnt out and needs replaced. open unit, and trace speaer wires to the small audio bd. remove board, flip over. if burnt, thats the problem. must replace.
Feb 01, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
