Honeywel thermostat which wires do i jump to check outside unit
  • 48 Answers
You will need to disconnect your R/Rc wire usually a red wire and your Y usually your yellow wire from the t-stat base. The run a jumper across to verify operation from you stat.
Posted on May 23, 2011
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
Honeywell RTH221
Try bypassing the control board by jumping the L1 wire with the high speed motor wire, if the motor runs then the board is faulty and must be replaced. If the motor does not run either the capacior is bad or the motor itself
Jul 08, 2012 | Honeywell Programmable Thermostat Heater
{my thermostat was flashing filter} I replaced filter and now air conditioner wont kick out cold air rth230b
Remove the thermostat wires and reconnect wires after 10 minutes. Then check. --------- yellow wire on thermostat is for cooling.Disconnect the yellow wire bolt remove yellow wire and then see if AC works will yellow wire unplugged..If its works that means the Thermostat is the issue.It has to be replaced. On some newer honeywell thermostats.there is blue wire instead of yellow wire.The connection is same, but blue wire is there instead of yellow wire.In that case disconnect blue wire and then see if AC works with blue wire disconnected. ---------- Check this.This will help.Thanks.Helpmech.
Jun 07, 2011 | Honeywell Heating & Cooling
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
T8000c honeywell thermostat is blank
This unit doesn't require a battery. It runs off the 24v from the unit. Check that your transformer is still working. Check the control board for 24v pwr. and main pwr. Check your breaker to the unit. It could be as simple as a bad stat too. You can check by using a jumper wire and jumping across from r term. to y term.
Apr 10, 2009 | LG Art Cool LA121CNP wall/window Air...
My heating/cooling blower (not the outside unit but the fan in the garage) does not turn off, even when my Honeywell TH8000 is set on automatic. What can I do to have the fan motor shut off?
try hard wiring your 24 volt that goes to the outside unit to the yellow wire coming back from your thermostat make sure the yellow wire is on the yellow terminal on the thermostat (honeywell) i have run into situations when this seemed to be the only thing that worked
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Intertherm to Honeywell thermostat
Typically if you have a yellow wire in the "y" terminal blue is used as common or "c". As far as your jumper from rc to rh, that will depend upon what type of heat you have. If all of your heat and cooling come from your packaged unit outside, yes you will need the jumper. If this does not work maybe you have a bad breaker or transfomer.
Oct 12, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
