Question about Singer 5050 Mechanical Sewing Machine
Dear Sir/Maam Bobbin casing on my sewing machine gets tilted and is not allowing machine to work.Motor works fine.Please help.The model # is 5040C.A prompt response is truly appreciated. Thankfully, Mrs.Koki Bhatia
  • Singer Master
  • 1,133 Answers
You could download an instruction manual from www.singerco.com website, link is http://www.singerco.com/accessories/manuals.html, type in your model number and press "search" to locate it.
The manual should assist you in troubleshooting the problem, it sounds like the bobbin case is either incorrectly inserted or faulty but go through the threading diagrams and see if this helps you to resolve it.
Posted on May 23, 2011
I am having a problem with the thread knotting up on the bottom of my material. The needle starts to lock up and when I start checking the thread is all knotted up. I then take the bobbin out and it...
What you have going on is probably a bobbin problem. The knots are referred to as birds' nests and happen usually happen when your bobbin thread gets caught on something in the bobbin area. To be certain it's a bobbin problem, change your needle. Even if the needle looks fine, it could be just slightly bent and still look fine to the naked eye. If that doesn't solve the problem, take the fabric out of the sewing machine and turn the machine wheel by hand. Watch what happens thru the plastic window in the bobbin area, or if you don't have a plastic window leave the bobbin covering off. Is the thread catching somewhere and causing a bunch of thread to gather in the bobbin area? Be very careful when investigating in the bobbin casing/area-it's easy to chip things in there! Often times, a piece of something falls in there and can be pulled out with tweezers. Just as often, the bobbin casing is slightly tilted and needs to be straightened or has a chip in it and needs to be replaced. You can normally get a replacement on eBay, searching with your machine model number. Also, check out SewVacUSA. If you need help replacing the bobbin casing (it's easy, you just need to be careful), or if these solutions don't work, leave me a comment. I check back daily, so I'll get back to you within 24 hours normally. Leave me as much detail as possible and I'll do everything I can to help you!
May 11, 2011 | Singer 3116 Simple
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
My thread is bunching up and excessively stitching under fabric
May 05, 2011 | Singer Sewing Machines
Model # 9113 - The thread bunches under the fabric but the top seam is okay.
When I am sewing the bobbin CASE that holds the bobbin gets loose and will move which will break a needle, jam the thread etc etc I have re threaded the bobbin, the upper thread and changed the needle a...
You may have the wrong size bobbin in there, if that is not it, it may be a scarred bobbin case. Tell me what machine make and model you have. If, you have plastic bobbin, it can cause horrible stitches, you can try a metal one, again, let me know what you have and maybe we can work it out.
Mar 31, 2011 | Singer Sewing Machines
The original bobbin provided with the machine is 11.5mm. But I could get only 11.4mm bobbin. Can I use that because in the manual it is said that we can't use other model bobbins.Please help.
Don't use it. The bobbin cases are designed to work with the specified bobbin size, see if you can track them down on Ebay or through a sewing machine dealer in your area.
Feb 28, 2011 | Brother XL-2600
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
Hi, I own a Husqvarna Prisma 940. It has always
I will help you,
Pls give the Model number of your sewing machine.
Jan 09, 2011 | Husqvarna Huskystar 207 Sewing Machine
ELNA 7000 no display on screen
Problem solved - I have a useful son! he took off the casing & cleaned 'circuits' . Now works fine. Wendy
Jan 30, 2010 | Elna Sewing Machines
KENMORE SEWING MACHINE MODEL 1792181
Call some local dealers and tell them what you are looking for. I,m sure one of them will have it,maybe even in stock. It's not always easy to know which bobbin case you need ( especially Kenmores) so be prepared to take in the old bobbin case or the bobbin or even the sewing machine for ready Identification.
Some helps; If your bobbin has holes all the way around then you probably have a standard case with a finger sticking up which you can get from any dealer. If you have a solid bobbin and a wrinkle finish paint on the machine you have an older machine and the dealer may have to order it for you. Be aware there are 2 different sizes of this bobbin case.You must get the right one for it to work.
sewman7
Jul 19, 2008 | Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
169 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
