Question about Asrock G31M-S Motherboard
I have a as-rock g31m-s R2.0 when i connect the connection for the front panel audio it doesn't work i dont no if it a configuration in the bios?
  • 36 Answers
You should check is the front audio even connected with the motherboard. Probably isn't, if the back panel audio works!
Posted on May 23, 2011
How to connect front panel audio I/O connector pin
here you go http://download.asrock.com/manual/G31M-S.pdf
Apr 29, 2014 | Asrock G31M-S Motherboard
Asrock G31m-vs audio not coming to speaker
Are you facing Same problem from both front and back side audio jack?
Aug 15, 2012 | Asrock G31M-S Motherboard
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
Nosound
Just to make sure desktops almost never have built in speakers.
1. Check that your speakers work. Try them with an MP3 player or other device to make sure they work.
2. Check that the speaker is plugged in the right socket. Play something on computer and switch around the plug.
3. In windows press START->Control Panel->System->Device manager.
Right click on Sound device and write down the make (Company and a model number).
4a. Google their website and go to support->downloads/drivers and download the appropriate driver.
4b. If its an INTEL sound device you might have to look up the motherboard as it might be bundled with the motherboard driver.
Jul 05, 2011 | Intel Computers & Internet
I cant listen to the sound in front panel
Probably as simple as the front panel is not connected.
Be sure the front panel cables are connected to the correct audio output connector/pins on the MB.
http://www.asrock.com/support/index.asp and get the manual
for the board so you know where and how they should be connected.
Jul 12, 2010 | Asrock G31M-S Motherboard
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Asrock G31M-S Motherboard Logo
208 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
