Question about Ryobi Garden
Replaced fuel line but having problems with leaking and also very hard to start
    Sergeant:
  • 287 Answers
Get correct size fuel lines.That will stop your fuel leak and stop it from sucking air fixing the hard start problem.
Posted on Mar 10, 2015
I have a 97 civic I am not getting fuel or spark
Most likely Camshaft sensor, located in distributor, is just the right age for that problem.
Jan 24, 2015 | 1997 Honda Civic
My prime bulb looses pressure and first start is hard. I have to remove fuel line from filter and cover with thumb prime re install then first start takes time.
Does the engine run fine after it starts? Most common problem with primer bulb losing prime is an air leak in the fuel line or primer bulb. Air leaks don't always leak fuel. If there is an air leak between the primer bulb and gas tank there is no pressure, only vacuum. If it is not a major leak it might not leak without pressure but it will allow air to enter the fuel line. If it is a very minor air leak it could allow air to replace the liquid in the fuel line over time, but so little air once it is primer again that the fuel pump can over come it with volume of fuel.
Primer bulbs do not stay firm, as they are when initially pumped up, after the engine is running. There are check valves in the primer bulb that hold pressure in the primer bulb and throughout the fuel line to the engine. Once the engine starts the fuel pump creates vacuum drawing fuel into the engine diminishing this pressure and releasing the check valves. At this point the primer bulb is just another segment of fuel hose allowing fuel to pass through it as the fuel pump demands. The primer bulb functions much better when the outlet side is higher than the inlet side. This position makes it easier for the check valves in the primer bulb to seat and release as needed. If the primer bulb is functioning properly and is positioned with the outlet side higher than the inlet it should not be necessary to cover the end of the fuel hose with your thumb to get it to prime.
If the engine is hard to start after being fully primed there could be a problem with the fuel system on the engine. Some engines are hard to prime once air has entered the system, especially fuel injected models.
Dec 19, 2014 | Boating
Flooded
engine hard to start smelling fuel first look under hood for signs leaking fuel lines if you raise hood get strong gas smell look for wet fuel leaks on top engine where fuel lines located.if see no leaks could have leak at fuel rails to fuel injectors.if see no leaks look under vechicle around fuel tank area look for fuel dripping.
Jan 29, 2013 | 2002 Dodge Durango
2002 yukon hard to start, where is the fuel filter and how to replace it.
FIRST RELIEF FUEL PRESSURE BY REMOVING GAS CAP REMOVE FUEL PUMP RELAY START ENGINE UNTIL IT DIES LACK OF FUEL. FUEL FILTER IS MOUNTED TO THE RIGHT FRAME RAIL.NEAR THE FUEL TANK.YOU NEED A FLARE NUT WRENCH TO LOOSEN FUEL LINE AT FILTER AND A ADJUSTABLE WRENCH HOLD FILTER LARGE NUT WHILE LOOSEN FUEL LINE THIS KEEP FROM TWISTING FUEL LINES WHILE LOOSEN FUEL LINE.BESURE TO GO TO DEALERSHIP AND BUY NEW O - RINGS AT FUEL FILTER LINES.LUBRICATE NEW O- RINGS WITH CLEAN ENGINE OIL.WHEN INSTALLING NEW FUEL FILTER DONT OVER TIGHTEN FUEL LINES CUTTINGTHE O -RINGS AT FUEL FILTER.IF SO THEY WILL LEAK GAS WHEN YOU START UP ENGINE.WHEN DONE CHECK FOR GAS LEAKS WHEN DONE DONT DRIVE UNTIL YOU CHECK FOR LEAKS FIRST.
Aug 16, 2010 | 2002 GMC Yukon XL
On cold mornings, will not start and just "turn over" replace fuel pump and complete tune up ..still the same problem
You may be weak on fuel pressure . even a couple of lbs low on a cold start will cause a no start.
Double check cold start cranking fuel pressure. If under 63-62 lbs you have problems.
one test is to give it a squirt of carb cleaner not starting fluid. If it starts then you have a fuel pressure problem.
Run the full fuel pressure test and post back pressures.
Here is the guide lines on testing.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
Post back fuel pressure readings.
The 75-85 is only a check on the capable full pressure of fuel pump.
If you can not find the rubber return line check full pressure by plugging return line or just or the true full pressure can be taken direct at the end fuel filter.
What are the pressure readings that you have done. Good luck and hope the fuel pump is not a bad one you put in there, it's know to happen.
Dec 23, 2009 | 2002 Chevrolet Blazer
Strong gas odor
  1. The fuel lines may have a leak: Replace leaking fuel lines and/or fuel line fittings.
  2. The engine may have mechanical problems: Check vacuum lines and fittings for leaks. Check engine compression. Check for broken fittings and mounts.
  3. The fuel pressure regulator may be operating at too high a pressure: Perform fuel pressure test and repair or replace faulty component(s).
  4. The ignition timing may be set wrong: Check and adjust ignition timing.
  5. The fuel injectors may leak: Clean or replace fuel injectors.
Sep 15, 2009 | 1996 Ford Explorer
Car want start
The mechanic should check on the fuel filters , the spray nuzzle and the fuel lines . The fuel filters "the primary and the secondary filters".If these filters are dirty fuel are hard to enter because the dirt keeps on blocking the fuel to pass or go to the engine . The spray nuzzle if it is also dirty then the fuel also is hard to spray or to pass for engine compression. The fuel lines if the fuel lines are worn out or have leak then it should e replaced. These spare parts if they are been worn out or dirty they should be clean or some times be replaced . for good so that fuel will not spill too much on the car.For these problems can cause fuel leaks or engine problems it will result to engine lubrication.
Aug 25, 2009 | 1996 Chevrolet Camaro
Fuel leaking into vacuum line on fuel pressure regulator
sounds to me that,yeah,the fuel regulator is bad,it should not let gas into the vaccum line
Apr 23, 2009 | 1999 Chevrolet Silverado 1500
Garden Logo
119 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
