Question about Whirlpool LGR5636L Gas Dryer
IGNITER AND GAS VALVE WONT WORK - Whirlpool LGR5636L Gas Dryer
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 25, 2011
Jandy Lite 2 is showing FL4 My igniter is turning red but no flame. DO I hve a gas problem?
see if you have 24 volts to the brown and yellow wires on the gas valve if wires are loose it wont work either if no voltage to gas valve bad pcb board if voltage to the gas valve bad gas valve
Aug 31, 2014 | Jandy Pool & Spa
Tappan series 110 the igniter is glowing but it wont lite the oven
Is the gas turned on at the stop valve behind the range? Assuming the gas is on, the igniter can glow but not actually be working properly such that the control valve does not open or the valve may be failed. There are electrical measurements for the valve and igniter and related circuit that can be made if you have a clamp on amp meter and a volt meter.
Nov 18, 2013 | KitchenAid KGSA906PSS Gas Kitchen Range
Old non electric wall heater. battery powered t-stat. the burner wont ignite till i bang on the gas valve after the t-stat is calling for heat. but it always works, burner ignites when i bang on the gas...
I would remove wires and connection one at a time and clean them carefully.Clean all terminals and check wiring for any breaks or cracks on insulation. I think you probably have some debris inside the gas valve that is interferring with the valve opening freely. Unfortunatly there is not much to be done other then what I've mentioned except for replaceing the valve. Good luck and thank you.
Jan 31, 2011 | Heating & Cooling
Blower comes on , then flame thing, but wont turn on flames
OK, I think the flame thing may be an igniter. So the inducer turns on, the igniter glows but the gas valve does not open so there is no ignition. Sounds like you may have either a bad gas valve or a bad circuit board. You will need to check for 24 volts at the gas valve. If you get voltage but no ignition, replace gas valve. If you get no voltage at gas valve, replace the circuit board.
Jan 23, 2011 | Goodman GMS807034ANA Heater
Igniter works but gas wont light
The igniter works but gas won't light because there's no gas being ignited at all. The gas valve solenoid coils are weak or broken preventing the valves to open and allow gas to fire up. Replace both solenoid coils and everything will be fine like new. The coils are located sitting on top of the gas valves and there are two of them. It is a cheap and easy task to replace them. Indicate the exact model number of the dryer should you need further assistance.
Dec 30, 2010 | Maytag Dryers
Oven wont light
This can be caused by a weak/inop hot surface igniter or a defective gas control valve.
One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure(burner does not come on) then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
Remember be very careful doing any of these procedures. Good luck and have a safe holiday.
Jul 04, 2010 | Tappan TGF320 Gas Kitchen Range
I have a coleman evcon furnace and it wont work it gives me a flash code of 1 what does it mean
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Dec 26, 2009 | Tools & Hardware - Others
Gas jets wont start they just make clicking sound
try oven if working gas valve system possible ok lift off covers to expose igniter looks like a little wire that arcs a spark to ignite gas clicking is igniter trying to spark ,clean area of debris if any, if no spark will need igniter adjuster /repaired or replaced and gas valve checked for proper function
Oct 19, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My Neptune dryer mdg5500awgg wont heat up. Any suggestions?
I am providing some links courtesy of www.repairclinic.com that will assist you in the diagnose/repair of your dryer.
Firstly, ascertain that you have made a positive heat selection on the control panel switch, then proceed onward.
Parts breakdown/disassembly procedures:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
1. Gas Valve Coils image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3479&PartID=3479
2. Ignitor image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3018&PartID=3018
3. Thermal Fuse image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di516650&PartID=516650
Aug 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
OVER WONT HEAT UP
make sure the hose is connected to the propane tank and that the tank valve is opened letting gas into the grill exhausts... and then light the igniter but make sure the release valves on the grill arent on max... start it on low to med.
May 27, 2009 | Bosch HGS3052U Gas Kitchen Range
Whirlpool LGR5636L Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
