I have a Matsui PL617 portable DVD player and when I put a video in it and press play there just appears a line on the screen. The sound is fine, but there is no picture.
techman
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
SOURCE: portable dvd player won't play
dvd player can not read disc
Posted on Apr 07, 2008
SOURCE: portable dvd player - wont play
Hi
Bought a dvd laser lens cleaner for 10 euro played it through the dvd player a couple of times and its working great now
thanks.
Posted on Apr 10, 2008
jan mczeal
  • 632 Answers
SOURCE: I have a model # PDV-288 portable protron dvd
ribbon loose connection..try to resolder connector terminals and realign ribbon connection..
Posted on Jun 14, 2009
SOURCE: does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Posted on Jun 19, 2009
Matsui PL700 lid won't close properly
no need to tighten the cap or whatever, that's the problem there is with the switch control, which must be touched when the lid closed. you just need to open the DVD case cover, then locate these switches, make sure the switch is still normal or not, if it is normal that you only need to give a little pad on the suppressor to the switch. suppressor usually exists on the DVD casing.
Jul 26, 2010 | Televison & Video
Tip
Matsui DVD-110 VCD Fix
Matsui DVD-110 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-110 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-110 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-110 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-110 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
Matsui DVD-122 Region Free Fix
Dvd player plays dvd but the screen only shows lines & the audio is fine.
Sounds like your av cables may need to be replaced or the DVD is bad. Check that the cables are in the correct ports coming from the DVD player to your television and that the cablesd have also been placed in the correct postitions.
Good luck
Nov 11, 2009 | Drive Mobile Entertainment MOBILE VIDEO 7...
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
Kawasaki PVS 10921 lines in screen
unplug the device from the main power cord.remove all the external wires connected from the player.then again reconnect it properly.also check out the disc in another player.or another disc in the same player.
Nov 27, 2008 | kawasaki PVS-10921 Portable DVD Player
Kawasaki PVS-10921 sound ok... lines on screen - picture very distorted
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 31, 2017 | kawasaki PVS-10921 Portable DVD Player
Portable dvd player
Polaroids are well known for this issue you can try to replace video cable if that doesnt work if still under warranty send it in if not you will need to make a video rca repair
c.
Sep 14, 2008 | Polaroid PDV-0700 Portable DVD Player
WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Jun 07, 2008 | Philips PET702 Portable DVD Player
Portable dvd player Film's stop and go back to loading screen
Not sure it's a solution, per se, but I discovered that my Matsui was acting as if I was opening and closing it, so I guessed that it was the lid. Once I put a paperweight on the "Press to Open" part of the lid, the DVD played through. I'm looking how to fix the lid but that's a workaround for now. Best of Luck - M
Jan 26, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
