Question about Juki MO-644D Mechanical Sewing Machine
Should the right hand needle be slightly longer than the left after changed? The right hand needle hangs a bit longer than the left. Is this correct?
  • Juki Master
  • 1,129 Answers
Yes, needles are usually offset on sergers, one will be lower than the other.
You can download a manual from here: http://www.jukihome.com/products/mo644d.html its a pdf icon on left of screen, page 11 covers needles and the right needle is lower. It also says to change the right needle first, then the left one and to use a JL x 2 needle in the left side for heavy weight fabric.
Don't know with the Juki but I know my Bernette prefers the serger needles as they have a scarf/groove in the front as well as the back, ELX705, otherwise they are the same length as the standard domestic needle 130/705H.
Also, never unscrew the needle screw too far out, just enough to get the needles out and in, as there is sometimes a ballbearing up in the housing between the two needles and if you wind out the screws too far, this may drop out.
Posted on May 23, 2011
  • Tally Girl
    Tally Girl May 23, 2011
    sorry, on the Juki website, click "Features" dialogue to find the manual link.
Needle hits the quilting presser foot
Needle may be slightly bent. Needle may not be properly or fully inserted into the needle clamp or holder. Needle may even have a burr on it or be too dull. Needles must be changed fairly often, especially with many of the modern synthetic fabrics. They do not last forever.
Change the needle first, for a new one, be sure it is properly inserted. Then, make sure you have not accidentally set your stitch width incorrectly. I've done that myself after using a zig zag stitch mode and forgetting to change it, or not change it all the way back to straight stitching.
Some machines will allow the needle to be set at centre, left of centre or right of centre, so be sure it's in the correct place for the stitch and foot you are using, or you will hit the foot.
Hope one of those turns out to be the right tip.
Oct 16, 2016 | Brother Sewing Machines
My bobbin theses is not getting picked up by the the needle, I tried opening the bottom, nothing wrong. I didn't use my new sewing machine for over a year. Before that I used it twice.
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 13, 2016 | Sewing Machines
The thread is not picking the bobbin
Feb 29, 2016 | Sewing Machines
Needle needs adjustment slightly to right, it is hitting left side of hole on baseplate.
There is an eccentric built into the needle bar frame that center your needle right were you want it. Adjust zig-zag at max, or just center the needle in the center of the needle hole.
Nov 22, 2015 | Sewing Machines
My needles are hitting lower looper
take it to a repair shop and get it timed .
Aug 09, 2015 | Sewing Machines
Needle keeps breaking
There are many possibilitys
1- the needle and the fabric have to match - soft needle to hard fabric and the needle breaks - you need a needle with a higher number ex.90
2- not threaded correctly
3 - thread tension is too High to the fabric
look in the manual
good luck
Jun 16, 2014 | Necchi 4595 Mechanical Sewing Machine
My bobbin seems to be incorrectly, after a struggle -now the needle keeps losing its thread, so I'm sowing with no top thread!!! What am I doing!!'
Assuming your bobbin is threaded correctly. Try to pull your top thread thru the needle a bit longer & suggest you turn your hand wheel towards you till the needle just poked thru the fabric, then only you start sewing.
Nov 08, 2013 | Sewing Machines
My left thread breaks even when i dont have material in the machine and also when i insert the needles the right needle is longer than the left is that supposed to be that way.
try rethreading the machine incase the thread is caught somewhere
also check the tension on the left needle is sound like it to tight
yes, on my serger one needle is a little bit longer too
Aug 11, 2011 | White Sewing Superlock 2000 ATS Mechanical...
My white 2000 serger is dropping the thread on the first needle when I sew with it- the loopers, both upper and lower are working correctly in conjunction with the "right upper" needle. I have changed...
Could be as simple as poor quality thread (not using MaxiLock thread), the needles not inserted properly (the left is slightly higher than the right), a missing stitch forming pin on the needle plate, the needle bar being too high or a looper timing issue.
As the needles raise, the upper looper should move to the right with the right needle tip slightly above the eye of the looper.
Jul 19, 2009 | White Sewing Superlock 2000 ATS Mechanical...
How do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Jun 08, 2009 | Singer 6038 Mechanical Sewing Machine
Juki MO-644D Mechanical Sewing Machine Logo
188 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
