Question about Poulan Pro 22inch 625 Series Briggs Stratton Gas Powered Side DischargeBagMulch Front Wheel Drive SelfPropelled Lawn Mower With Electric Start And High Rear Wheels PR625Y22RKP
I have a poulan electic start mower and the key is not working. what could be the problem?
    Sergeant:
    Champion:
  • 226 Answers
Recoil starter
Posted on May 23, 2011
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
Why does my Poulan 625 lawn mower when using the key start makes a whirring sound and not start?
maybe this might help, some of the newer engines have an oil alert. if the oil level is low it won't start.
Aug 01, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Why wont my poulan riding mower start with the key and new battery keeps going dead
clean all the connections from battery to starter, selonoid connections to and ground cable where it connects to the battery and to where it connects to the frame it might just be a bad connection on frame i seen alot of poulans with this problem.
Jun 06, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan push mower won't start
Remove the spark plug and pour a teaspoon of gas into the spark plug hole then replace the spark plug and it will start.
Aug 06, 2009 | Poulan "Poulan" Push Mower
Severed Shear Pin Poulan P35TN20SE
First and foremost check to see if the crankshaft was bent when you hit the culvert. Remove the spark plug, Tilt the mower on its side at a 45 degree angle and while someone slowly pulls the starter rope see if the shaft where the blade attachs wobbles. If it does then you will need to replace the crankshaft (which can be expensive in some models). If it isn't bent, then the shroud that covers the flywheel is removed along with the other parts in that area and a flywheel "knocker" is used to remove the flywheel. At this point the old key is visible and you can see if it is sheered or not, If it is, then reverse the directions just followed after replacing the flywheel key. Chances are 99% it isn't the key, but the crankshaft.
Jun 14, 2009 | Poulan "Poulan" Push Mower
Poulan Pro 22inch 625 Series Briggs  Stratton Gas Powered Side DischargeBagMulch Front Wheel Drive SelfPropelled Lawn Mower With Electric Start And High Rear Wheels PR625Y22RKP Logo
255 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
