Question about Cobra Microtalk 100 FRS Walkie Talkie Radios 2 Pack
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
The higher capacity batteries are fine (they'll just take longer to reach a full charge), the problem is that the original batteries have the negative contact extended as a band around the bottom of the battery. The charging tab at the bottom of the unit makes contact with the negative end of the first battery through a springy contact inside the battery compartment that touches this band. You don't have to buy expensive Cobra batteries. The easy fix is to wrap some aluminum foil around the bottom of the battery that touches the springy bottom side contact. Be sure the foil also covers the bottom end of the battery), or you could cut away the outer plastic battery cover (at the bottom) to expose the metal shell like this: http://www.walkie-talkie-radio.co.uk/replacing-cobra-walkie-talkie-rechargeable-batteries.html
Posted on Dec 18, 2013
  • 3,018 Answers
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
Posted on May 23, 2011
  • Iron
    Iron May 23, 2011
    In short if you try to charge any battery in that radio but the specific one that is suppose to be used not only will it not charge but you risk fire.
    Regards,
    Tony
What battery is needed for Cobra Model #PR3850?
just have to wrap a bit of tin foil over the bottom of one battery and use normal nimh rechargeables. The Cobra's have a seperate circuit that must be made to differentiate between normal AA and rechargeables. The OEM battery has an exposed metal ring on the bottom of the battery. If a normal AA is put it and allowed to attempt to charge, it will start a fire. If you look, there is one contact at the negative end of one battyery that must be made for it to allow to charge in the base. You could scrape away the plastic, but a wrap of tin foil did the trick for me.
Oct 26, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
I just put new batteries in my Cobra microtalk PR 3500 DX battery charger. How long will it take to charge them? Should the Radio's be in the on or off position. Thank You mjbarry42@comcast.net Mike...
The radios will work fine while being charged, but they will charge faster if turned off. Normal charging time is 8-10 hours, but I would recommend an overnight charge - they won't overcharge or be damaged by the longer charge time.
Bill B.
Nov 05, 2010 | Cobra microTALK PR 3500-2 DX VP 2-Way...
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Jun 28, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Radio Communications Logo
995 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
