Question about Car Audio & Video
How do you line up the timing chain on a 2000 pontiac grand am 2.4
  • 6,674 Answers
This should help. Look at "A" for cams and "B" for crank.how do you line up - motor1258_3.gif
Posted on May 23, 2011
2.4l. Removed timing chain. How do I reinstall it?
Google 2004 Pontiac Grand Am 2.4 timing chain line up marks,
Select pictures and it will show you how to line everything up.
good luck.
Jan 03, 2016 | 2004 Pontiac Grand Am SE
2000 pontiac grand am, when attempted to start engine cranked over for a couple times now want turn over at all, a mechanic said engine is seized. could it have jumped time or what.
no it can not jump timing it has a chain. have your tried to turn the motor by hand. meaning asocket and rachet on the harmonic balancer bolt
Dec 19, 2012 | 2000 Pontiac Grand Am GT
Grand am gt 2000 how to check timing chain?
Says timing chain?and engine knocks when accelerate,timing chain not going to cause that knock,
Nov 23, 2012 | 2000 Pontiac Grand Am GT
Timing specs on 2002 grand am 2.2 liter dual over head cam wont to know how to time the top 2 cam
rotate the engine till the crankshaft sprocket mark lines up with the second silver link on the chain, should @ the 5:00 position. on the right sprocket or the intake sprocket align the intake diamond with the copper link should set at the 2:00 position, and the triangle on the exhaust sprocket should line up with the other silver link in the chain approxamately at the 10:00 position. Once you get it in time, it is a good idea to put a bar on the crank and turn the engine over one complete revolution, just to make sure you got it timed right. hope this helps
Nov 28, 2010 | 2002 Pontiac Grand Am
How do you replace a timing chain for a 2000 pontiac grand am se?
what size engine they different for each engine. they not to bad . only if you have good mechanical skills.
Nov 20, 2010 | 2000 Pontiac Grand Am GT
Replaced water pump on my 2000 grand am timeing is now off how do i set it correctly
The timing is set by the computer. Unless you removed the timing chain during the water pump replacement, there shouldn't have been a change. Check to make sure your wiring is connected tightly and the wires are all plugged in.
Sep 26, 2010 | 2000 Pontiac Grand Am GT
Where do i find a diagram of the timing belt and pully for a 2000 grand am on the internet?
your vehicle depending on eng size dosen't have a timing belt, only a chain, so you'll probably have a easier time finding a timing chain diagram and needed pullys. You will need to specify engine i.e. 2.8, or 3.1 or 3.4 or 3.8,... info will be located on sticker under hood typically white with black print rectangular or square shaped
Nov 14, 2009 | 2000 Pontiac Grand Am GT
How to and where are witness marks to reinstall timing chain on a 2000 Pontiac Grand AM 2.4
YOU WILL SEE A HOLE IN THE CAM GEAR THAT A 3/8 BOLT WILL FIT INTO. PUT A BOLT INTO THE HOLES OF BOTH CAM GEARS. THEN LINE UP THE CRANK PULLEY KEYWAY AT ABOUT 12 O'CLOCK WITH THE MARK ON THE ENGINE BLOCK.
MAKE SURE TO COMPRESS THE CHAIN TENSIONER AND RELEASE IT WHEN THE CHAIN IS IN POSITION.
Aug 27, 2009 | 2000 Pontiac Grand Am GT
Need timing marks for a 1996 pontiac grand am se 2.4 DOHC
May 31, 2009 | 2001 Pontiac Grand Am SE
Where are the timing chain marks ona 2000 pontiac grand am
On a 2.4, there are no timing marks...There are holes in the cam gears that need to be aligned with corresponding holes in the head.
Though it's not terribly difficult to do, it must be done precisely according to instructions or valves will hit the pistons and destroy the engine. You can find instructions for this procedure in haynes and other vehicle service manuals. (too long to write out here).
Remember...this is an exact install...you cannot just get close!!!
Good luck! Post back if you need further specific instructions with any part of the job.
Apr 23, 2009 | Pontiac Grand Am Cars & Trucks
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
