Question about Casio FX-115ES Scientific Calculator
I can get pi, but then when i need to multiply it by a number (example: 6), It just gives me that number, with the pi sign beside it. it wont give me an answer.
  • Casio Master
  • 7,993 Answers
When in MathIO the calculator displays pi symbolically. If you want the numerical value of an expression, press [SHIFT][=], not just [=]. You can try pressing the [SD] key to toggle between fraction`/radical to decimal. You can also configure the calculator to use LineIO by default.
Posted on May 23, 2011
What formula do you use to calculate cylinder volumes
Volumes are any three dimensional measurement...
I Seriously doubt that I could get Pi ("pie") to print...
But I'll just GIVE YOU the number (much simpler)
Pi = 3.14159
Inches, feet, yards or meters.. all the dimensions need to be in the same values... So if you have an inch "ruler"...
That is just fine...!!
Your first step would be to determine the diameter of the inside of your cylinder in inches...
CONVERT that to the RADIUS by DIVIDING by 2...
Multiply that RADIUS by itself and then by 3.1416 = area of circle in INCHES... (radius "squared" x Pi = (square inched)
Then MULTIPLY the height (in inched) by the AREA...
EQUALS THE VOLUME in CUBIC INCHES...!!
But I'll just GIVE YOU a REFERENCE (much simpler)
mathematical constant ?
Area of circle
Feb 18, 2017 | Office Equipment & Supplies
Area of circle
(pi)R squared (Fixya won't let me use the sign for Pi)
Area of a circle=pi*radius^2 or pi times radius times radius
example: suppose the radius of a circle is 10 inches, then the Area of the circle would be pi times 10 times 10 or 100*pi
pi represents the circumference (distance around) of a circle / diameter and for any circle is constantly the same number which is approximately 3.14
so in my example 100*pi=100*3.14 or 314 square inches
Jul 03, 2014 | Computers & Internet
Multiplying mixed fractions
Convert each mixed number (what you call mixed fraction) to an improper fraction, then multiply the two numerators and multiply the two denominators. Reduce the resulting fraction to its simplest form
Example
(2 1/3)*(1 5/7)=?
Convert 2 1/3 to an improper fraction 2 1/3=2+ 1/3 = 6/3+1/3=7/3
Convert 1 5/7 to an improper fraction 1 5/7=1+ 5/7 =7/7 +5/7=12/7
(2 1/3)*(1 5/7)= (7/3)*(12/7)= (7*12)/(3*7)
The 7's in the numerator and denominator cancel one another leaving
12/3=4
(2 1/3)*(1 5/7)=4
Not all products of mixed numbers will give a simple result as this one. More likely they will not.
Dec 12, 2013 | Computers & Internet
It wont give me the value when i multiply like 6 x pi
Your calculator may be able to use the symbol Pi. If it gives you a result with Pi, you should convert it to a decimal approximation. There must be a key to convert.
Nov 12, 2013 | Canon F-719SG Green Scientific Calculator...
Have a texet fx1500 scientific calculator. when I press pi button, it gives the answer 3 instead od 3.14. why?
Do you have the display set to give you any digits after the decimal point? What do you get when you multiply pi by 100: 300 or 314?
Mar 19, 2013 | Office Equipment & Supplies
Texet fx 1500. i press pi key. instead of 3.14 gives me the answer 3. why
When i try to use the pi key with another operation it does not compute. For example if I am trying to multiply 10 times pi, the calculator reads 10pi
Press the FD (fraction to decimal) button after you calculate 10 times pi, This will give you the
calculation in decimal form.
Mar 11, 2011 | Texas Instruments TI-15 Explorer...
How do I generate a random number that is greater than 1 on a casio fx-300MS
The random number function always generates a number between zero and one. You can convert this to a random number in any range by a suitable combination of multiplications and additions. For example, if you want a random number between zero and ten, multiply the generated random number by 10. If you want a random number between one and ten, multiply the generated random number by 9 and then add 1.
If you want to simulate the roll of a six-sided die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a 1, 2, 3, 4, 5, or 6 with more-or-less equal probability.
Mar 10, 2011 | Casio FX-300MS Calculator
Need tub capacity
Instructions
Things You'll Need:
* Measuring tape
1.
Measure the depth from inside the washer with a measuring tape. Start from the back of the inside of the washer towards you to the front of the washer. Measure the depth from a top loading washer from the bottom of the inside of the washer to the top. For example, a washing machine may have a depth of two feet.
2.
Measure the height inside the washer unit. The height inside the washer is from the bottom of the inside of the washer to the top of the inside of the washer for a front loading washing. The height is from one side of the inside of the washer to the other side in a top loading washer. For example, the inside of a washer may be one and a half feet, or 1.5 feet.
3.
Divide the height calculated in step 2 by two, and square it. In the example, 1.5 divided by two equals 0.75, and 0.75 to the power of 2 equals 0.5625.
4.
Multiply the number calculated in step 3 by the depth of the washing machine. In the example, 0.5625 times two equals 1.125.
5.
Multiply the number calculated in step 4 by Pi to determine the capacity. Pi is generally estimated as 3.14. In the example, 1.125 times 3.14 equals a washer capacity of 3.5325 cubic feet
Dec 21, 2010 | Washing Machines
How do you use the pi button? I want to multiply 42 by pi and it gives me the answer of 42pi.
Well, 42pi is the result of multiplying 42 by pi, isn't it? In the default MthIO mode the calculator strives to display as many results symbolically as possible.
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Sep 17, 2010 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
242 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
