Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Oxygen 3 Ultra powerhead replacement parts?
Hello,  I own an Oxygen 3 Ultra that has had some hair caught around the belted end of the roller brush.  I cleared the hair out just fine and it happened again but this time the hair wrapped around the black nylon roller retainer (for lack of its proper name).  This eventually melted due to friction and the brush no longer runs as the retainer no longer has the guide that holds it in place.
The repair to get this working again is minor but I can not locate the parts.  While I can find replacement roller brushes and entire EL5 housing I can't find replacement retainers.  Where is there a good source for such parts?  Is there a junk yard of Oxygen 3 Ultra's somewhere to pick through?  Thank you.
  • 1 more comment
  • Anonymous Dec 05, 2008
    ditto on all of that......where can one find a replacement power head for the Electro Ultra??
  • Anonymous Apr 06, 2009
    This is the biggest piece of junk vacuum I have ever owned
  • Anonymous Apr 12, 2009
    Same thing just happened to mine. This vacuum works great, but from the hose down, is a piece of ****. I've replaced the hinged powerhead coupling four times already because it broke.
You have to buy a new roller
Posted on Apr 19, 2009
My dyson animal is working but the brushes will not turn around so it only has suction any ideas
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 29, 2016 | Dyson Vacuums
Why doesn't brush roller rotate?
The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
Oreck brush only turns a tiny bit and belt pulley get hot belt not turning much either
If your brush is not turning properly then you need to check the bearing ends to see if there is any hair, string, or thread wound around the brush shaft. If there is and you can remove it, that might fix your problem otherwise I would suggest getting a new brush roller.
Jun 30, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My Bissell Model 3760-4 is not working properly. The belt has been replaced (and checked 3 times), but the brush bar does not move when the brush motor button is on. The little metal turning piece that...
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
May 12, 2017 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hello, My Electrolux Oxygen motorized brush stopped working. How do I determine if it is the switch, a belt or something else that is causing the motor not to work?
Hey Lee,
We had the same problem and after taking it to a service guy who didn't even want to LOOK at the vacuum, it occurred to us to plug the powerhead brush directly into the handle and it worked! So, we were able to determine that the problem was the tube - not the brush.
We ordered a replacement tube.
Hope this helps.
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Burning rubber smell when turned on. checked the belt-is ok.
Take the bottom off as if to change the belt and remove the brush assembly from the VAC. Take the ends off the roller and clean out the string and hair and whatever is wrapped around the end bushings and reinstall. Should free-up the roller Brush and stop the resistance on the belt to motor shaft. Or your belt is streched out and should be replaced, they don't always have to Break to be bad.
Aug 18, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
871 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
