Question about Nokia 6131 Cellular Phone
Nokia 6131 housing
I just changed the housing for my nokia 6131 and now i have no sounds/tones, just vibrates and the main screen isnt working, the mini screen lights up but with no image. Ive taken it apart and together again a few times to make sure all connections are secure but still nothing. What have i done wrong and can i fix it? shelly_rachy@hotmail.com. Many thanks.
Http://www.eserviceinfo.com/downloadsm/29953/Nokia_6133%206131%206126.html
This link will help you with re-assembly. I had the same snag. A GENTLE adjustment of the speaker contacts fixed the problem with sound. Use the above link to check your display connections.
Posted on Sep 08, 2008
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
No sound from phone
your speaker may not work properly you need to change the speaker
Oct 02, 2009 | Nokia 6131 Cellular Phone
Main Display
Hi. Have you tried replacing the LCD screen? You can buy one herehttp://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see thedisassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nov 14, 2008 | Nokia 6131 Cellular Phone
I have nokia 6131. its main display is not working properly. only welcome screen come & meanwhile main display goes blank.
Hi. Have you tried replacing the LCD screen? You can buy one here http://www.formymobile.co.uk/proddetail.php?prod=6131lcd and see the disassembly section of the following file for fitting https://www.yousendit.com/download/Y2o4WGJEY1NxRTFMWEE9PQ
Nokia 6131 problems after changing housing
llok michelle i am a professional phone repairman
i think u shud chek the belt that connect the two parts of the phone screens and keypad. and if its connected well and the phone still just like it was u shud change that damn belt cuz its very sensitive electronic stuff always watch out with the belts
Aug 16, 2008 | Nokia 6131 Cellular Phone
No tones on nokia 6131
check your buzzer if it was still ok, using tester set it in X1 if the buzzer creates sratch sound if you connect your testprove in the terminals of your buzzer it was ok but if you cant hear any sound, it was defective, so you have to replace it. good lack........
Jul 18, 2008 | Nokia 6131 Cellular Phone
Main screen not desplaying when I open up my Nokia 6131
Try turning the phone on with the flip screen open. Do it a couple of times if it doesn't work the first time.
Apr 28, 2008 | Nokia 6131 Cellular Phone
Change housing on nokia 6131
Dear shazza40
I have the guide for you please ask me/send me your email because I have no direct link for you to download.
Many Regards
Please rate this solution if you found it helpfull, thats what keeps us going!
Mar 31, 2008 | Nokia 6131 Cellular Phone
Nokia 6131 Cellular Phone Logo
163 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
