Question about Wahl Designer 6 (8355100)
I took apart my wahl contour to clean the blades and cannot figure out how to put the blades and the two other peices back together.
  • 3 Answers
SOURCE: I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
  • 30 Answers
SOURCE: Noisy wahl hair clippers
1st remove the blade. Once the blade is off grab the blade drive between your fingers, if it moves side to side without any spring pressure than the drive arm is loose from the armature. If that is tight, than the armature may be loose and lifted out of alignment. There are two screws on the right hand side of the case which hold the armature. If the screw is phillips head it is standard thread, if it is torx head it is reverse thread. loosen these screws and press down firmly on the armature. The top of the armature should be even with the top of the motor coil. If the drive lever as mentioned earlier is seperating from the armature then this should be warranty repaired by the manufacturer.
Posted on Sep 21, 2009
SOURCE: My friend took hers apart to clean and did not pay
how do i reassemble the wahl pro series pet groomer
Posted on Oct 18, 2009
  • 10 Answers
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
Posted on Jan 03, 2011
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
I took it apart to clean it but, like a dummy cannot put it back together. dog trimmer model 9765
Your style came with a DVD, can you find that??? I just can not find a manual that is in print form to assist you, sorry!!! Guy
Sep 12, 2010 | Wahl 9765-301
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
Jun 08, 2009 | Wahl 8550
Took unit apart to clean and need reassembly diagram please
Dec 02, 2008 | Wahl 8550
Wahl Designer 6 (8355100) Logo
212 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
