Question about Miller Welding Tools
I have a welding machine PowCon part 103203-001 serie SM4 82997, can I transfer this 600 volts machine to 220 volts ?
jgwhomeequip
  • 1902 Answers
SOURCE: transformer 110-220
Less expensive to replace the heating element. But if you already have a 1000 watt transformer then just go that route
Posted on Feb 22, 2009
  • 31 Answers
SOURCE: Voltage: own a 220 volt Series 3 330 shaver , now in Canada 110 v
You can try dryer power port, it's 220V, and you have to buy a adapter to replace the port on the wall accord with your Braun, or to buy a transformer (110 - 220).
Posted on Mar 10, 2009
maxtreadmill
  • 832 Answers
SOURCE: QUINTON CLUB TRACTURNED MACHINE ON..THOUGHT IT WAS 220 VOLTS..SAW
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
Posted on Mar 02, 2010
espressonist
  • 1711 Answers
SOURCE: Conversion from 110 volts to 220 volts
Inside the machine you have the vibrating water pump, the two heating emelents the grinder motor and group motor that are all are working with the 110. The cost of the above parts only will cost more than the price of new machine in any voltage. Moreover just consider the cost of labour for someone to make the modicifcations.
So as you may understant the only way to work your machine is to use a trasformer from 110 to 220 volts but again for a power of 1400 Watts this also a costly thing however you can try to find one but I believe it will worth it only if it is less than 100 Euro which I am no so sure if their in such a price. The only chance is if you can find a used one maybe from ebay or something which will do the same jop but very dificult to find one but worth it to try.
Hope that help you, Good luck
Posted on Apr 10, 2010
SOURCE: My snap on welder isn't working properly. With the
I own and love my Snap-On YA-212A and had a similar problem that turned out to be a power issue, not a welder issue. Repair costs and parts availability of these welders can vary wildly, it may be cheaper to replace it with a Lincoln, Miller, or Hobart. Snap-On uses more than one supplier to make their welders, if you tell me the exact model number I can probably tell you who manufactured it,
For now, try the following:
  1. Unplug the welder from the power outlet on the wall
  2. The power cable where it connects to the welder should be a twist lock type, make sure it is not loose. Take it off and look for any signs of arcing that look like it may have been a bad connection
  3. Look at the power connector that plugs into the wall and look for signs of arcing. If possible, take the back off the plug that goes into the wall and ensure that everything looks tight.
  4. Put the power cable back on the welder
  5. If your breaker box has a load controller turn it off and try your welder again
  6. Replace the circuit breaker in the breaker box on your house
Posted on Feb 28, 2011
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
How do I fix a hand blender?
i think your voltage there in the US is 110 volts so you need a step up transformer to get 220 volts for you hand blender..
Sep 13, 2015 | Braun Hand Blender 600 Watt 220 Volt -...
Lost power to my redcat 220 ac/dc welder
You say you lost power to the welder. Did you check the circuit breaker where the power comes from in the breaker panel?
It will be a 2 pole breaker. If you mean the welder quit, then you will have to unplug it from 220 volt and open it up where the wire goes into the welder and see if the fuses are blown, if they are replace with the same type of fuses and try to weld again. If they blow again then you have a bigger problem and you should have a welding person take a look at it.
Oct 13, 2014 | Welding Tools
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
I have an kenmore 600 series clothes dryer. It's about 1.5 years old. The dryer tumbles. gas and electric are on but no heat.
It is most likely the element if it is an electric dryer. If it is a gas dryer be sure that the pilot light is on for the gas at the valve.Also this machine is most likely under warranty so check it out.
I am 90 % sure that is an electric dryer so I would check to see that one of your breakers for the dryer are not tripped as one can run the dryer but it needs two to get the heat running as it runs on 220 volt.
Oct 06, 2010 | Dryers
Wire feed
first the handler 120 is 110volt,the handler 220 is 220 volt.the rubber wheel is for welding aluminum.
Feb 09, 2010 | Welding Tools
Jan 29, 2010 | Exercise & Fitness
Mar 10, 2009 | Health & Beauty
Kitchen aid mixer, voltage issue
i want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Nov 10, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Welding Tools Logo
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
