Question about General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator
Condenser fan barely runs on ge profile fridge model number pfs22sisbss resulting in an increased temp in the freezer section when I put a small external fan outside to cool the coils temperature has returned to normal. The questin is is it a bad fan or a bad control unit (motherboard) Thanks
  • 3,740 Answers
The bearings on the condensor fan motor are dry. You can attempt to lubricate the motor with a parifin based oil using either Union 76 "Turbine Oil" or a product called ZOOM-Spout turbine Oiler that is available in most hardware and appliance parts stores. See this link for examples of the oiler: http://www.google.com/search?q=Zoom+Spout+turbine+Oil&hl=en&safe=off&pwst=1&rls=com.microsoft:en-ph&prmd=ivns&source=univ&tbm=shop&tbo=u&ei=sqPZTcivKISEvAPOv-G_Bw&sa=X&oi=product_result_group&ct=image&resnum=3&ved=0CCoQzAMwAg&biw=1003&bih=587
Do what you can to clean off the bearings and armature shaft then lubricate with the oil.
Most of the time lubrication will snap a tired fan out of running slow. On the hard molded motors (encased) lubrication takes much longer as you have to lubricate and wait for the oil to reach the lower bearing deep inside the housing. It is ok to oil from the top and let it run to the lower bearing. It will not hurt the fan. I place the fan on a paper towel for as long as I can and wait for the exvess to drain off before re-installing the motor. On the non-encased motors you can remove the bearings and clean the motor shaft and the bearing then lubricate reassemble and lubricate again.
If your using an external fan... it is OK to use the refrigerator while your waiting for the oil in the motor to drip out. Just make sure there is a 15 minute pause each time you remove power or the compressor will not re-start properly.
Thanks for choosing FixYa,
Kelly
Posted on May 23, 2011
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
GE Profile- Freezer/ Fridge at 56 wont go cooler!
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
May 03, 2008 | GE Profile PSW26P Stainless Steel Side by...
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
I have a stainless GE profile PSS26SGPASS side by side fridge and suddenly the freezer and fridge wont hold the temp settign I put. The fan works, the controls work to lower the temp setting but it isn't...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 26, 2011 | GE Refrigerators
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Open Questions:
General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator Logo
708 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
