Question about Briggs & Stratton 2200 PSI Gas Pressure Washer
My pressure washer doesnt seem to run properly. i have changed the fuel,air filter,spark plug and the oil. It will start but runs poorly.
  • 2,527 Answers
Ok the first thing you need to check is if the spark is fireing. To do this you need to remove the plug plug it into the spark plug cap hold it on the cylinder head pull the engine over it will pull easy and see if you have a blueish spark jumping the gap on the plug . If you do its not an electrical prolbem . Then put the plug back and plug the ignition wire back and remove the air cleaner see if it will start then .witch the choke on . If it still won't start try pouring a small amount of fuel derictly into the carbuator if it runs for any time at all or even starts to fire then its a fuel issue eighter bad fuel or clogged filter or carbuator needs to be cleaned. You can even put a small amuont of fuel right into the spark plug hole then put the plug back in and it should start You need spark fuel and air for any engine to run if you have all three its automatic it will at least fire Good luckwith this
Posted on May 23, 2011
Replaced motor, starting hard. runs fine . how do I check fuel pressure
Doubtful you have a fuel pressure problem if the car runs well, poor starting can be a few things , poor air circulation air filter needs cleaning or replacing, poor injector flow warn injectors or just dirty fuel additive sometimes clears this , poor spark plugs not firing under pressure ok when started . for diesel cars you don't say what car it is , poor glow plugs . bad fuel filter , air leaks in fuel pump , poor injectors . and especially with diesel poor compression due to worn rings or head gasket failure . You may even have just have disturbed the engine earth strap when you replaced your starter motor .
Jul 03, 2015 | Cars & Trucks
What parts do I change to tune up my 2008 dodge caliber
For a standard tune-up, the parts needed include an air filter, oil filter, fuel filter, spark plugs, and spark plug wires. You should also have oil, transmission fluid, coolant, windshield washer fluid, and brake fluid available. A tune-up consists of topping off or replacing fluids, changing spark plugs and spark plug wires, changing the fuel, oil, and air filters, and checking the pressures of the tires. More detailed tune-ups run a diagnostic test on the vehicle to check for any codes that indicate additional issues.
Mar 16, 2014 | Cars & Trucks
What parts do you change when you get a tune up?
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
My engine won't start.
The oil light began to flicker beacuse of low oil pressure with the lower RPM I expect. Four things for your engine to run: 1, Spark, 2, fuel 3, compression and lastly the timing.
While running at higher RPM how well (or poorly) does the engine run?
This may be as simple as a clogging fuel filter, low pressure = poor fuel stream which = poor performance.
May be the fuel pump failing too.
Other ideas; starved for air, very dirty air filter?
Also corld be crank, cam or MFA sensor too. Sart easy with the fuel filter and work from there.
If I may be of additional help, please let me know.
Tom
Apr 25, 2010 | 2001 Mitsubishi Eclipse
93 volvo 850 glt changed the fuel pump now car wont start. Engine cranks, fuel pump working, fuel getting to the motor but it wont start. The car had trouble starting sometimes so i changed the fuel...
Check your fuel pressure to ensure proper pressure to the block, also did you replace the fuel filter.
On a side note: 3 things a automobile needs to run
AIR-make sure you have a clean air filter and your MAF (mass air flow sensor is plugged in) if you pulled your breather to innspect anything, there is a possibility that it came unplugged or you unpluged it and forgot to hook it back up, a car wont start without it being plugged in if equiped
SPARK-Make sure your car has juice to the plugs, if the plug doesnt fire the car wont run, if you have to pull each plug and ground them to the engine block to see if they arch. If not trace the problem down (if you changed the fuel pump you have some mechanical skill and should be able to troubleshoot a spark issue)
FUEL-Check for proper pressure, dirty fuel filter(s) and if your system has a return line, make sure your hoses didnt get crossed cause this will damage the engine and regulator.
Hope this helps Thanks for using Fixya.com
Jan 22, 2010 | 1994 Volvo 850
Trying to figure out the best things to do for a tune up on my 2000 mitsubishi galant
Start by changing spark plugs,air filter, fuel filter,even oil and oil filter as the engine smells how clean the oil is with oxygen sensor for starters.Check electrical connections and hoses for tightness,if its not running well run a big dose of fuel cleaner through the petrol tank and give it a good run,check ignition timing(if you can)otherwise if its running poorly,get a mechanic to attend to it to diagnose it properly and easily
Dec 01, 2009 | 2000 Mitsubishi Galant
2002 ford focus is geting poor gas milage
Tune Time.
1)new spark plugs properly gapped.
2)new air filter (check every 35000 miles)
3)new fuel filter (every 35000 miles)
4)1 bottle of STP fuel treatment (red bottle) 4x a year.
5) oil and filter change (castrol or another good quality oil every 3-4000 miles.
6)proper air pressure in tires (check every 2 months
7) service transmission every 40000 miles or less.
New oil and filter
8) new plug wires every 80000 miles.
Nov 07, 2009 | 2001 Ford Focus
Briggs & Stratton 2200 PSI Gas Pressure Washer Logo
403 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
