Question about Xerox Phaser 8500/DN Printer
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
  • 2,574 Answers
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
Posted on Oct 19, 2011
2 Suggested Answers
  • 57 Answers
SOURCE: xerox phaser 8560 DX error
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Posted on Jan 19, 2011
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
I have an 8560 MFP with a 04,024,45 error
Power OFF the Printer and Contact Support for Assistance. That's what the support website states. If you run out of warranty Xerox will charge you a call out fee before they even look at the printer.
Mar 15, 2011 | Xerox Phaser 8560MFP Laser Printer
We have a problem with a Xerox 8560 MFP with this error 37,008.44:34849. We don't known where is the problem. Can you help us ?
There is a problem with the power up of the printer. For 37,00x.xx error codes you can try power off the printer, wait 30 seconds and power it back on. According to the Xerox website for 37,008:44 error code you should Verify the Printer's Power Source and Isolate the Printer.
Nov 18, 2010 | Xerox Phaser™ 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... oolivas@gruposion.com.mx cvalabacillascity@hotmail.com
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser  8500/DN Printer Logo
746 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
