Question about Chamberlain Keyless Entry
How do I change the keyless entry code to another number
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
How to change the code on a Chamberlain Keyless Entry Garage Door opener
How do I add, program or change a Keyless Entry PIN?
Your new Keyless Entry must be programmed to operate your garage door opener.
Program using the "Learn" Button
  1. Press and release the "learn" button on the motor unit. The learn indicator light will glow steadily for 30 seconds.
  2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
  3. Release the button when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Program using the Multi-Function Door Control
NOTE: This method requires two people if the Keyless Entry is already mounted outside the garage.
  1. Enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold ENTER.
  2. While holding the ENTER button, press and hold the LIGHT button on the Multi-Function Door Control.
  3. Continue holding the ENTER and LIGHT buttons while you press the push bar on the Multi-Function Door Control (all three buttons are held).
  4. Release buttons when the motor unit lights blink. It has learned the code. If light bulbs are not installed, two clicks will be heard.
Change a Known, or Existing Pin/Code
If the existing PIN is known, it may be changed by one person without using a ladder.
  1. Press the four buttons for the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
  2. Press the new 4-digit PIN you have chosen, then press ENTER.
The light on the motor will blink once when the PIN has been learned.
Test this by pressing the new PIN, then press ENTER. The door should then move.
I hope you find this helpful. If you need further assistance please let me know!
Have a great day! :)
Carrie
Posted on May 24, 2011
2 Suggested Answers
SOURCE: sears keyless pad
I am not sure how to upload a file on here but I have the instructions for programming the key pad. if you would like a copy let me know!!
Here is a link from sears but you have to register your e-mail address to view it - no major thing!
Hope this helps!
http://www.managemyhome.com/mmh/products/ManualSearch.action?sid=MMHMxSearsx00019&product.modelNumber=13953684&product.brandName=CRAFTSMAN
Posted on Oct 10, 2008
Lost keyless entry code
Keyless entry code was on a small strip attached to the left trunk hinge in my 94 T-Bird. It wasn't anything fancy just a 1/4x2" strip with 5 numbers on it Your owners manual should give you the location, but mine was kind of vague like drivers side of trunk.I hope this helps
Feb 03, 2010 | 2000 Ford Crown Victoria
I need to change my code for my wireless keyless
GOTO LIFTMASTER.COM YOU CAN DOWNLOAD A FREE PDF VERSION OF YOUR MANUAL
Jan 31, 2010 | liftmaster Chamberlain Garage Door Opener...
Need to change the factory keyless entry code OR the module
Programming your own personal entry code
To program your own code:
5. Enter factory set code (keypad will illuminate when pressed).
6. Press 1/2 control within five seconds of step 1.
7. Enter your personal 5 digit code.
Enter each digit within five seconds
of previous one.
8. After the code is entered, the
locks will cycle, confirming that the
new code has been set.
Do not set a code that includes five of the same number or presents
them in sequential order. Thieves can easily figure out these types of
codes.
Keep in mind, if the battery is ever replaced or goes dead, the keycode will revert back to the factory setting.
Sep 23, 2009 | 1999 Mercury Mountaineer
How to change keyless entry code when I don't know the current
Open the right/rear door. Pull the rubber weatherstrip back from the door opening. Fold the right/rear seat back down into a locked position, in order to access to the right/rear trim panel. Carefully, pry the right/rear upper trim panel housing the right/rear seat belt height adjuster. Now carefully pry back the lower trim panel taking care now to break it, exposing the vehicle security module with three connectors plugged into it, coloured green, blue, and grey. Look on the label that has the part number which should end in EB. There are FIVE numbers to the right of that number. Those five numbers are your keyless entry keypad code.
Sep 15, 2009 | 2004 Lincoln Aviator
PASSENGER SIDE ROTOR RUBBING INSIDE CALIPER SUPPORT AFTER CHANGED HUB ASSY
Bill look under dash on drivers side find the keyless entry module, the bold numbers on the module are your factory keyless code, hope this helps
May 23, 2009 | 1995 Ford Explorer
Numeric door codes
you can find the keyless entry codes for the number pad, to unlock and lock your truck, on the keyless entry module, located under dash left side, the code will be the numbers in bold print, these are the factory code numbers
May 22, 2009 | 1997 Ford Explorer AWD
Would like to rekey my auto-keyless entry and cannot find the code near the instrument panel.
your factory code for keyless entry by number pad? this is found on the module for keyless entry located under dash left side, number on module in BOLD type is the original or factory code
May 18, 2009 | 2004 Ford Expedition
I need to get keyless entry numbers
the keyless entry code is on a plastic "credit card" in the owner manual packet. This is the permanent code and can be changed by you, following the directions in the owner manual.
Your selling dealer probably recorded the codes in your sales folder. Also, you can go to any Ford dealer parts dept with ID and proof of ownership and they can get your code from Ford using your 17 digit VIN number.
May 04, 2009 | Ford Taurus Cars & Trucks
CHANGE CODE ON KEYLESS ENTRY SYSTEM FORD EDGE
Yes you can program your own code by inputting the original code then hit the no. 2 button then input your own 5 digit code.
Mar 16, 2009 | 2007 Ford Edge SEL Plus
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
Chamberlain Keyless Entry Logo
729 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
