Question about Dell XPS M1330 Notebook
When i start up my computer it says no bootable devices--strike f1 to retry boot, f2 for setup utility press f5 to run onboard diagnostics
    Problem Solver:
  • 10 Answers
Well I think the problem is that it can't find the hdd or it is not booting from it, to fix boot up your laptop as soon as you boot up the laptop start pressing f8 until a screen appears when the sceen appears select the hdd option (a few other options should pop up as well) and after you have done that sit back and wait. If that does not work you might have to take out the hard drive and then put it back in.
Posted on May 23, 2011
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
When i turn on my laptop it is telling me that there is no internal hard disk drive not found. To resolve this issue try to reseat the drive. Then it tells me there are no bootable devices--strike F1 to...
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Aug 29, 2010 | Dell Inspiron 1525 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
My laptop wont start up..its saying "internal hard disk drive not found..To resolve this issue, try to reseat the drive.." NO bootable devices--strike F1 to retry boot, F2 for setup utility or PRESS F5 to...
This message it telling you that the PC cannot "Find" your drive. This usually happens if the drive has failed or the "Boot Track" has been corrupted. Well,I suggest, to try all the "Options" first, press F1...If it boots all good... if still no good... then press F2 and make sure the Hard Drive shows in the setup. If it does NOT show there, it is probably best, to then run the diagnostics, but I am fairly sure at this juncture it will tell you your hard drive is kaput, and you will need to replace it. If it does show up, then we need to fix the boot track... insert your Windows DVD and do a repair,and running the Fixboot command from recovery console.
Jan 30, 2010 | Dell Inspiron 1521 Notebook
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
HARD DISK NOT FOUND
Your hard drive is not detecting , for this open the case , remove the power connector, and bus cable, then connect it again, then power the cpu and check
Sep 23, 2009 | Dell OptiPlex GX270 PC Desktop
Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Apr 21, 2009 | Computers & Internet
Dell XPS M1330 Notebook Logo
230 people viewed this question
Alun Cox
