Question about Minka Aire Ceiling Fans Gyro Traditional Model F502-PQ in Platinesque. Indoor fan
How to take cages off fan to clean , we have tried everything, do you need a special tool? we have two f 502
Replace clutch plate
Hi, takes a while to do but reasonably easy. Only downside is you need a few special tools to lock the clutch cage and remove the clutch. These tools are not cheap and most bike workshops won't lend them out readily. You can try though or see if anyone you know has the necessary tools. Good luck.
Jan 28, 2014 | Suzuki VL 1500 Intruder LC Motorcycles
Marcy Upright Fan Cycle - Fan Hitting Cage As It Spins
You did great with the assembly, however, you're off on the alignment. Try to adjust to pull the axle in the opposite direction to clear the cage.
Nov 11, 2013 | MARCY MCPL 105 Upright Fan Bike
Fan picks up dust
Dear friend,
You need to clean the outer cage of the fan with the help of a dry paint bursh or a dry tooth brush.
Later, open the cage and clean the blades by spraying liquid cleaner and wiping it with dry cotton cloth, alternatively you can use water to clean it.
Regards,
Priyank Abhineet.
Oct 18, 2012 | Heating & Cooling
I do not know how to clean this fan. Do I need any tool for cleaning this fan? Thanks
generally a soft brush should work fine. Also if you have it compressed air will help. this can be doen without opening up the cage. but opening up the cage might make it easier
Aug 28, 2011 | Vornado VF20 Table Fan
How do I remove the hard drive from a m7580n HP desk top? I cannot reach the back screws is there a special phillips head tool required?
did you remove the cage? You have to take out the entire cage to be able to remove the harddrive from the cage itself.
May 16, 2011 | Computers & Internet
The fan blades are hitting the back of the cage
Just a suggestion. Make sure the back part of the cage is securely fastened to the motor housing. Good Luck,
Wayne
May 27, 2010 | Lasko 1820 Stand (Pedestal) Fan
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
HOW DO YOU CHANGE THE HEATER BLOWER MOTOR?
YOU NEED TO TURN OFF RADIO TO KEEP FROM LOSING RADIO CODE.REMOVE NEGATIVE BATTERY CABLE.THAT WILL DISABLE AIR BAGS.WAIT 30 MINUTES.SO THE AIR BAGS CAN DISCHARGE.THE BLOWER MOTOR IS LOCATED ON THE PASSENGER SIDE OF VECHICLE UNDER THE INSTRUMENT PANEL.WHEN REPLACING THE BLOWER MOTOR.YOU HAVE TO REMOVE THE SQUIRREL CAGE OR BLOWER MOTOR FAN.BY REMOVING THE METAL STAR CLIP RETAINING THE FAN CAGE TO THE MOTOR SHAFT.REMOVE THE FAN BY PULLING STRAIGHT OUT.TO INSTALL BLOWER FAN TO NEW BLOWER MOTOR.INSTALL THE FAN CAGE ONTO THE MOTOR SHAFT .ADJUST THE FAN CAGE TO GET A CLEARANCE OF 0.30 INCH TO THE MOTOR MOUNT PLATE.INSTALL EVERYTHING VISA VERSA.BESURE TO BUY A REPAIR MANUAL.SO IT CAN SHOW YOU WHERE ALL YOUR PARTS AND SCREWS ARE LOCATED. WARNING IF YOU HAVE ANY DOUBT ABOUT THIS TASK.LET THE DEALERSHIP DO IT.
Oct 13, 2009 | 2005 Chevrolet Impala
I bought an older unit Viking Ultra line range hood. I'm cleaning it and wonder how I should go about cleaning the blades of the squirrel cage fans. Thanks. Karen
I took the motor out of the range hood. There is a set screw holding the squirrel cage fan in place which I unscrewed enough to slide the fan part off. I then boiled the part in a deep pan with lots of dish soap. I then brushed away the remaining debris. Avoid using dishwasher detergent which is effective but seems to erode the aluminum.
Jul 07, 2009 | Viking Kitchen Ranges
Minka Aire Ceiling Fans Gyro Traditional Model F502-PQ in Platinesque. Indoor fan Logo
29 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
