My Maytag Ensignia Model No. MAV7557EWQ washer spin cycle is not spinning, it will drain the water at the spin cycle, but will not spin the water out of the clothes.
  • 90 Answers
SOURCE: maytag mav6458 washer
Sounds like a broken transmission
Posted on Jan 05, 2008
  • 351 Answers
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Posted on Mar 08, 2008
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
  • 67 Answers
SOURCE: Admiral Washer........Spin cycle not working.
BAD LID SWITCH
Posted on May 18, 2009
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
My washer is still spinning the cloths but the clothes are much wetter that they used to be after the spin cycle. Any ideas of how to trouble shoot?
Check your belts and also check the drain hose to be sure it is pumping the water out at a good pace. Hope this helped.
Jun 08, 2011 | Maytag Ensignia MAV4758AWW Top Load Washer
My Maytag Ensignia is filling with water then stopping. If I manually move it through the cycle it does nothing. Won't spin or drain. There is no noise when it goes to the agitate or spin cycle (as if it...
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. You will need a putty knife to release the clips located of the front corners of the of the lid. If you look along the seam of the top and the front panel, just near the corners, you will see them. Just push in on the clips and lift the top to access the switch.Here is a link to the part.
Jan 04, 2011 | Maytag Ensignia MAV3757AWW Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
All cycles work on washer but does not spin the washer will drain water but does not spin at all
your tranny linkage is either stuck ! worn out! of just jammed from running out of balance its located in the bottom on the machine on the transmission
Jan 14, 2010 | Maytag Ensignia MAV4758AWW Top Load Washer
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Clothes are still wet after spin cycle
possibly not a machine fault. if drain is connected to sink plumbing, remove the drain hose and see if it pumps out into a bucket.
Mar 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
