Question about Dryers
Replace belt on whirlpool awz220 - pulley confguration
2 Suggested Answers
  • 731 Answers
SOURCE: I have a whirlpool awz220
Service manual is available here:
http://www.nodevice.com/manual/newmans/whirlpool/8575_220_01010pdf/get51511.html
Posted on Dec 14, 2010
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Have to replace broken belt on a whirlpool awz 7813 tumble dryer and wondered what way the belt runs around tensioners
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Sep 30, 2010 | Whirlpool Dryers
How to replace the belt on a whirlpool duet washer
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet model GHW9100LQ1belt slides to back of pulley
DO YOU HAVE THE CORRECT BELT? DO THE GOOVES MATCH THAT PULLEYS? IS UR MOTOR PULLEY ON GOOD? DO YOU HAVE ANY RESTRICTIONS IN UR DRUM /BASKET CAUSING IT NOT TO TURN?
ARE YOU USING HE DETERGENT?
May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
372 people viewed this question
Top Dryers Experts
