Question about Sport & Outdoor - Others
I have 94 yamaha g4 golfcart gas 4 stroke the motor boogs down when climing a hill and when it warms up after 20 ninutes or so the motor starts backfiring and loses power the backfire will stop after a couple minutes I rebuilt the motor,new carb,fuel pump,fuel filter,changed coil it has good voltage any help
  • 1 more comment
  • Edward Rankin Sr. May 23, 2011
    yes , I readjusted the valves,cleaned muffler,adjusted govenor
    I pulled the clutch side cover ,I install new piston,rings,rod bearing,seal & gaskets new valves & seals I checked the timing gears on cam and crank and theywere matched up. The compression is 145 lbs.the clutches are shifting good ,has a new belt,does the tci ign. module have anything to do with the timing
  • Edward Rankin Sr. May 24, 2011
    it's a new fac. replacement carb,fuel pump & fuel filte stock air filter, I took it off &no changeI open up muffler ,it was clean but I drilled extra holes for better flow,no change
  • 496 Answers
What all did you do when you rebuilt the motor? i only ask because there are may ways to "rebuild" something. it sounds like your timing might be off a tooth. check this for me and get back with me so i have some things to work with.
1) timing is spot on
2) the valve clearance
3) the carb, jet sizes and air/fuel screw setting
4) the cvt tranny is working the way is should and the belt is not stretched out of spec.
5) spark plug color.
Why i think the timing is off is because of the back firing, timed ign. is key and if it is off even a tooth it will make you chase your tail. that could be causing your boog as will. and the cvt tranny if the belt is over stretched it will cause the tranny to not work right lack of top speed and pick up.
look over the things i asked about and please get back with me. i can help figure this out with you if your willing to be my hands.
Looking forward to hearing from you
M.Woodring
Posted on May 23, 2011
  • 1 more comment
  • mark woodring
    mark woodring May 23, 2011
    the ing. box does not have anything to do with the timing it's just told when to tell the plug to spark. can you do a leak down test on it?
  • mark woodring
    mark woodring May 24, 2011
    Man it sounds like the motor is sound, stock jets in the carb, stock air filter and exhaust
  • mark woodring
    what color is the plug
  • 10,319 Answers
Have the valves been checked for proper clearance?
that will benefit your problem
Posted on May 22, 2011
No power on exceleration smells like gas hs a hard time pulling hills 94 saturn sohc 1.9
Start by replacing the air filter and checking the operation of the fuel pressure regulator. Have the stored codes read out of your ECU, either by an auto parts store or a local mechanic, in order to ascertain a starting point for diagnosis.
May 08, 2015 | Saturn Cars & Trucks
I have a yamaha big bear 350 engine bogs down when climing a hill
Could be a problem with a bad float that is overloading the engine with fuel. Does it take a little bit to "clear its throat" once you are on flat ground again?
Mar 07, 2014 | K and N Yamaha Big Bear Yfm350fw Air...
Model identification of Yamaha 15 four stroke
YAMAHA MODEL
YEAR GUIDE
EXAMPLE:
"F15MLHW" would
be a
Four Stroke, 15 HP,
Manual Tilt/
Manual Start, 20"
Shaft, Tiller Steer,
1998 model
THESE CODES ARE
GOOD FOR USA
MODELS ONLY
If you are outside
the USA we can
only help if you
have original
Yamaha part
numbers.
Please contact
Yamaha in your
area to buy a parts
catalog for your
motor.
Jan 27, 2013 | Boating
Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a new Tohatsu 6HP, 4-stroke motor on a sailboat. Is there a secret to starting it without pulling on the d... cord 20 times? Even then it may not start. Kind of scary if I am out on the lake and...
Yes, I think I know the problem because I have the same motor and mine starts right up every time. When you cold start it, you may not be priming it enough...it doesn't have enough gas. Don't squeeze the bulb 2 or 3 times, do it about 10-12 times. Full choke and it will light right up. On a warm start, you don't need to prime it or choke it. On a semi-warm start, try half choke and no priming.
Jan 11, 2010 | Light Outboard Motor Boat Bass Fishing...
What is the ratios of oil to gas?
32 to 1 equals 4 ounces two stroke engine oil per one gallon of gas. Be sure to use two stroke engine oil and not motor oil.10w40 motor oil is for the gearbox.
Dec 19, 2009 | 2003 Yamaha YZ 125
Oil Leak at exhaust flange
No major problem. The proper mix is 32 to 1 gas and oil. That equals 4 ounces of 2 stroke ENGINE oil to one gallon of gas. Do not use MOTOR oil in the gas. 10w40 motor oil is what goes in the gearbox. Tighten the exhaust flange.
A top ranking please ... Thanks BJS!
Apr 25, 2009 | KTM 250 EXC Motorcycles
Sport & Outdoor - Others Logo
150 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
