Question about Garden
Need the manual for an older model MTD model 604 riding lawn mower Want to change oil. Where's the plug? What grade oil should I use? Bought this mower second hand and it works good
    President:
  • 1,545 Answers
The drain plug is either on the bottom of the crankcase under the deck or on the side of the engine where the square-head bolt is. I realize you won't be able to "tilt" the rider to drain it. I suggest using SAE 30 oil. I also highly suggest you use synthetic. If you use synthetic, you can use a multi-viscosity like SAE 10-30W. But if you use conventional, just plain SAE30. I will need some time to try and find your manual if it is available for a PDF download. Sometimes, you can order a paper copy off of the parts lists menu for the machine if and when you find that listed by an online vendor that carrys parts for an older machine. I will post back if and when I find the manual.
Posted on May 22, 2011
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
I need a parts manual for mtd model 95178.riding lawn mower
Go to MTD website and down load a manual.
May 13, 2014 | Mtd Garden
Need an Owners Manual for my 17.5 hp 42" cut Pony Troy bilt riding mower, Model 13AN779G766183630 Serial 1E045B30725000004
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Sep 01, 2011 | Mtd Gold 13AA625P004 50Inch 502cc 230 HP...
Need belt diagram for mtd lawn mower model 13al667f118
Have you checked the owners manual?? I think that is a pretty simple routing, described in the manual. If you don't have it:
http://manuals.mtdproducts.com/mtd/Safety.do?pid=168747&model_num=13al667f118&serial_num=00000&filename=770-8637m.pdf
Aug 09, 2011 | Mtd Garden
I need a manual for a 1998 or 1999 gardenway lawn tractor by MTD troybuilt Model #13AI617H118 Serial #1A082H10211 can you help? It's a 21H tractor 46SDIt's up above
Most of the MTD product manuals are available here: http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Just fill in the model and serial numbers.
I found two separate manuals listed: lawn tractor owner's guide and the engine operator's manual. I found the manuals only opened in IE (Windows OS) after clicking the I Accept button. The direct links are: http://manuals.mtdproducts.com/mtd/Safety.do?pid=152292&model_num=13AI617H118&serial_num=1A082H10211&filename=770-10317b.pdf and http://manuals.mtdproducts.com/mtd/Safety.do?pid=152290&model_num=13AI617H118&serial_num=1A082H10211&filename=274794.pdf .
I hope this helps.
May 14, 2011 | Mtd Garden
We have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Jun 12, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
